Pvc in pods
- Pattenrd
Pvc in pods
23 May 2023 15:39
Probably not on topic of kz but my son bought a 77 Suzuki es? 750 the guy he bought it off of hase pvc pipe in the throat of carbs into pods bike runs ok vm26 carbs never heard of it anybody else
- F64
- 81-KZ440D2
Re: Pvc in pods
23 May 2023 16:57
Probably not a good idea as reversion will send gas mist back towards the filters.
PVC doesn't like some of the items contained in gasoline.
HDPE may be better.
hdpesupply.com/hdpe-straight-length-pipe/
HDPE may be better.
81-KZ440-D2.
LIC, NY
LIC, NY
- Pattenrd
Re: Pvc in pods
23 May 2023 17:03
The question is why would you do this the PVC is inside of the pods going to eliminate it and rebuild carbs I've had a lot of bikes never seenit before
Re: Pvc in pods
23 May 2023 18:14
Seems like that would really restrict flow at high rpm, which would negate the advantage of the individual filters.
- F64
- 81-KZ440D2
Re: Pvc in pods
23 May 2023 19:42
Ask the guy you bought it from.
That's the easiest way.
We could all fathom reasons but humans do weird stuff all the time. I know I do.
Just take them off and start the tuning process.
81-KZ440-D2.
LIC, NY
LIC, NY
- Pattenrd
Re: Pvc in pods
25 May 2023 04:15
They are in the trashcan now going to do mild restoration including carburetor rebuild and new pods with air correctors thanks for your response just never seen this before on a bike
- blipco
- 2002 KZ1000P
Re: Pvc in pods
25 May 2023 05:21
Could we see a picture of this? I’m guessing the effective throat size of the carb has been cut down substantially.
- Injected
Re: Pvc in pods
25 May 2023 05:29
Sounds like a work around to use wrong size filters on the mouths. I have done this but only on the outside of the carb mouth but not the inside as its too restrictive.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Re: Pvc in pods
25 May 2023 05:51 - 25 May 2023 05:54
Be sure that you buy high quality filters like those sold by APE, Uni and K&N. There are cheap Chinese knockoffs that will give you endless headaches because they do not flow properly and often block the air corrector jets, so be sure you get the genuine articles.
Last edit: 25 May 2023 05:54 by TexasKZ.
- Pattenrd
Re: Pvc in pods
26 May 2023 17:53
I have done a couple bikes over didn't look like the hot set thanks for the replies onto my project 77 kz1000 A1 son will figure his bike out
