97’ police choke shaft
  • Aragone79
  • Aragone79's Avatar Topic Author
17 May 2023 07:04
#884794
I picked up a 1997 project police bike and the carbs do not have a choke shaft or any of the parts for the choke.  I found the part number for the shaft but I’m wondering if it comes with the pieces that actually connect the shaft to the choke plungers and if not does anybody know the part numbers for that?  Thank you!
  • TexasKZ
  • TexasKZ's Avatar
Re: 97’ police choke shaft
17 May 2023 18:41
#884821
  • Nessism
  • Nessism's Avatar
17 May 2023 18:51 - 17 May 2023 19:53
#884822
Those sorts of parts are hard to come by.  You may have to buy a set of parts carbs to get what you need...and even junk sets cost a lot of money these days.
Edit: you need these, among other things.  The forum software has problems with eBay links, so remove the spaces...
https:    //www.ebay.com/itm/125936975424
The little 1/8" balls, you can get anywhere.  You will need the little springs, though.
Last edit: 17 May 2023 19:53 by Nessism.
  • Aragone79
17 May 2023 19:52
#884823
Thank you for the link!  I have been contemplating another set of carbs mainly because it’ll probably end up costing about the same.  But like you said, they are pricey!
