fuel lines diagram 1995 kz1000p
- MALCOLMHOULE
Re: fuel lines diagram 1995 kz1000p
10 May 2023 14:03
ok - here is a simple one - the air box hoses connecting to the carbs...they are curved. how are they supposed to be set up? curved upward or to the outside? .
10 May 2023 14:09
They have medication for that! Don’t be ashamed!
10 May 2023 14:17They curve outwards, the carbs are wider than the airboxok - here is a simple one - the air box hoses connecting to the carbs...they are curved. how are they supposed to be set up? curved upward or to the outside? .
The following user(s) said Thank You: MALCOLMHOULE
10 May 2023 14:18They have medication for that! Don’t be ashamed!
10 May 2023 14:57 - 10 May 2023 14:58so, from the carbs they curve inward, but from the air box, they curve outwardThey curve outwards, the carbs are wider than the airboxok - here is a simple one - the air box hoses connecting to the carbs...they are curved. how are they supposed to be set up? curved upward or to the outside? .
Last edit: 10 May 2023 14:58 by TexasKZ.
The following user(s) said Thank You: Wookie58, MALCOLMHOULE
- MALCOLMHOULE
10 May 2023 22:18
well im on a roll so ill keep going im rebuilding the petcock - new inerds —-the square plastic piece between two thin rubber membranes has a little notch in one corner - does it matter what side it is on?
- MALCOLMHOULE
11 May 2023 13:45
I assume it is just a tube to let air in to avoid creating a suction? So maybe it doesnt matter?
11 May 2023 15:33
It is a vent and it does not care. However, that small protrusion next to your finger in the first picture does care which way it is oriented.
By the way, if you click the Insert All button before submitting a post, the pics will show up full-sized in the post and readers will not have to click on them too see what you are asking about.
- MALCOLMHOULE
13 May 2023 09:50
So Far:
New spark plugs - this made it run on 4 cylinders rather that 2 ... there is hope...
New Stator (Ricks Hot Shot)
New Regulator/Rectifier (Rick's Hot Shot)
Carburetor - torn apart cleaned in detail - all new o rings
New Carburetor mounts and boots
Rebuilt Petcock
Gas Tank Float cleaned / new gasket
New fuel lines, vent tubes
The Good News - the bike runs like a champ.... it started up in the first crank and drives like new ( at least from the engine perspective)
Bad News - Electrical Issues still ... I started a new thread in the appropriate section...
Thank you everyone for your help _ Love this forum!!!
Rebuilt Petcock
- MALCOLMHOULE
13 May 2023 09:55
well i had to learn the hard way but it is done - all sealed up with no leaks. thats a win in by book
13 May 2023 10:27
Feels good, doesn’t it. That is part of why we love these ancient dinosaurs.
