BS34's #3 carb bowl leaking
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
11 Apr 2023 17:09
#882944
float is set correctly
needle and seat are sealing fine
i'm really stumped as to what is going on here
could it have something to do with the vacuum, this carb has vac line to petcock
fuel gasket isn't too bad but this isn't due to leaky gasket solely
any help would be greatly appreciated  thanks
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
  • Away
Re: BS34's #3 carb bowl leaking
11 Apr 2023 17:52 - 11 Apr 2023 17:53
#882947
How about checking the petcock?   Install a section of line onto both the fuel outlet and vacuum lines.  No fuel should flow out when the petcock is set to ON or RES.  Sometimes when the petcock fails, it sends fuel down the vacuum line.
Last edit: 11 Apr 2023 17:53 by Nessism.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
11 Apr 2023 18:21
#882949
thanks nes
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
13 Apr 2023 17:57
#883082
while searching the forum i'd read someone say they'd changed bowls and gasket which resolve the issue.
so i followed suit and it seems to have corrected the problem for now. thanx all
1982 KZ1100D1
