Carb Idle tool
- ffltstn
Carb Idle tool
10 Mar 2023 19:26
I have '82 KZ1000J, When syncing the carbs the screw is held in place with a 3/8" nut.
What are you using to hold and tighten that nut? Special tool? Crowfoot?
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
'95 Voyager XII
'98 Vulcan 750
Re: Carb Idle tool
10 Mar 2023 19:33 - 11 Mar 2023 09:06
3/8"??? You mean 10mm 8mm?
Edit: thanks to TexasKZ for correcting my mistake.
www.z1enterprises.com/carb-adjustment-tool-set.html
Last edit: 11 Mar 2023 09:06 by Nessism.
Re: Carb Idle tool
11 Mar 2023 08:44
The tool at the link says 8 mm.
Re: Carb Idle tool
11 Mar 2023 09:05Thanks for the correction! Yes, it's 8mm. Sorry.The tool at the link says 8 mm.
- Cra-z1
Re: Carb Idle tool
11 Mar 2023 11:36 - 11 Mar 2023 11:37
This is what I use. You do need to use an auxiliary tank however.
www.saber-cycle.com/Carburetor-Adjusting-Tool_p_1445.html
Last edit: 11 Mar 2023 11:37 by Cra-z1.
Re: Carb Idle tool
11 Mar 2023 14:41
I never knew they were so cheap, when I had my Harris (many years ago before the Internet) I made one by welding a cheap 1/4 drive socket to a bent piece of 6mm rod and passed a screw driver through the socket
Re: Carb Idle tool
11 Mar 2023 17:15No worries, 10mm is darned close to 3/8 inch.Thanks for the correction! Yes, it's 8mm. Sorry.The tool at the link says 8 mm.
- ffltstn
Re: Carb Idle tool
11 Mar 2023 17:28
OK thanks everyone. didn't know they made such a tool. I get a new toy!!
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
'95 Voyager XII
'98 Vulcan 750
Re: Carb Idle tool
11 Mar 2023 19:58
Not the save all you might think, at least on my Big fours, the upper frame rail position will not allow you to get straight on the adjuster of carb 2 & 3. I use a stubby screwdriver and an m8 wrench. I have the one Cra-z1 posted
- slmjim+Z1BEBE
Re: Carb Idle tool
12 Mar 2023 07:00Same one we use. Cane from Motion Pro many years ago. Aux tank and a big floor fan completes the stationary tuning setup.This is what I use. You do need to use an auxiliary tank however.
Mama Kaw offered a Z1-specific, VM28SC carb sync tool (PN# 57001-120) individually, that was also part of the Z1 shop tool set that enables the stock tank to be in place while syncing Z1 carbs. The convenience of being able to do so is somewhat offset by the notable discomfort of working in very close proximity to the hot intake cam cover. We've seldom used it since obtaining the tool like Cra-z1 linked to. Mechanic's gloves help.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
