Engine don't start; ideas please!
  • Claude.
  • Claude.'s Avatar Topic Author
Re: Engine don't start; ideas please!
20 Jan 2023 16:52 - 20 Jan 2023 17:21
#879082
...FYI there is no electrical connection between the coil and the bracket or the frame ( only "heat transfer")
Seriously? Don't the coils need to be grounded via their mounting posts?
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
Last edit: 20 Jan 2023 17:21 by Claude..
  • Nessism
  • Nessism's Avatar
20 Jan 2023 17:43
#879084
Thinking at Nessism comment, I told myself "why not invert the coils's wires. Naah, it won't work as the right colors are on the right coils". Having nothing to loose, I did so. And the engine started RIGHT AWAY!! What a relief. I don't know why I had to invert the wires but I'm so glad that I don't really care by now.
Once again, thanks a lot for every comment!! I really appreciate!
If the coil wire colors are correct, that means the rotor is on 180 degrees off.  It's easy to do.
The following user(s) said Thank You: Claude.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
21 Jan 2023 00:43 - 21 Jan 2023 00:51
#879100
No, the primary winding grounds through the points/igniter module (switching the ground is what makes the spark) the secondary winding grounds through the spark plugs to the engine on a dual output coil or shares the ground via the points/igniter on a single out coil. The mounting tower simply dissipates the heat generated to stop the coil burning out
Last edit: 21 Jan 2023 00:51 by Wookie58.
The following user(s) said Thank You: sf4t7, Mikaw, Claude.
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
20 Aug 2023 23:14
#888545
He said his green wire is on 1/4
My 82 1100 shows black to 1/4 and green to 2/3
Unsure if they differ on yours
1982 KZ1100D1
