Engine don't start; ideas please! 20 Jan 2023 16:52 #879082
  • Claude.
  • Claude.'s Avatar Topic Author
  • Thank you received: 34
...FYI there is no electrical connection between the coil and the bracket or the frame ( only "heat transfer")
Seriously? Don't the coils need to be grounded via their mounting posts?
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
1982 KZ1000J2 (another one!)
2017 Yamaha FZ07
Last edit: by Claude..
Engine don't start; ideas please! 20 Jan 2023 17:43 #879084
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Thinking at Nessism comment, I told myself "why not invert the coils's wires. Naah, it won't work as the right colors are on the right coils". Having nothing to loose, I did so. And the engine started RIGHT AWAY!! What a relief. I don't know why I had to invert the wires but I'm so glad that I don't really care by now.
Once again, thanks a lot for every comment!! I really appreciate!
If the coil wire colors are correct, that means the rotor is on 180 degrees off.  It's easy to do.
The following user(s) said Thank You: Claude.
Engine don't start; ideas please! 21 Jan 2023 00:43 #879100
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1787
No, the primary winding grounds through the points/igniter module (switching the ground is what makes the spark) the secondary winding grounds through the spark plugs to the engine on a dual output coil or shares the ground via the points/igniter on a single out coil. The mounting tower simply dissipates the heat generated to stop the coil burning out
The following user(s) said Thank You: sf4t7, Mikaw, Claude.
Last edit: by Wookie58.
Engine don't start; ideas please! 20 Aug 2023 23:14 #888545
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
He said his green wire is on 1/4
My 82 1100 shows black to 1/4 and green to 2/3
Unsure if they differ on yours
1982 KZ1100D1
