Petcock questions
  • Claude.
  • Claude.'s Avatar Topic Author
Petcock questions
09 Jan 2023 15:53
#878696
Fuel petcock question
(NOTE: I don't want a Pingel petcock; I want to use a vacuum operated unit.)
I do have two KZ1000J here with OEM petcock that works perfectly so I know those vacuum operated units can fulfill their goal.
I'm currently restoring a 1983 KZ750L that have a leaking OEM petcock ("reserve" and "on"). "Prime" works as it should. I first tried to replace it with a complete (eBay chinese) one but it also leaked as described above. I took the OEM unit apart (rubbers were worn out) and installed the chinese's inners inside the OEM one (after a deep cleaning). Same leaking. I even shimmed the vacuum spring for a stronger closing force but it leaked up to the point it could not open anymore under vacuum…
Then, I ordered a petcock repair kit (still eBay chinese) that I received today. I installed it and same leaking. After a few (well, more than a few) curse words, I don't know what to do next.
I do have another spare OEM off a 1982 1000J that I could try to use (possibly with that repair kit I received today) but I'm not optimistic…
Are Chinese really unable to make leakproof petcock or repair kit? Does only OEM parts that works? I could order OEM's 43028-1015 diaphragm but will it work?
This 750 is a bike I intend to sell so I don't want to spend a ton of money on it.
Thanks!
Kawasaki 43028-1015 - TAP DIAPHRAGM | Partzilla.com
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: Petcock questions
09 Jan 2023 16:34
#878698
My first choice is always OEM parts if I can get them. Lately, I've been purchasing rubber parts from  Sumo Rubber  They seem to have a good reputation.
Also, rebuilding petcocks is more than just replacing the rubber bits. This tutorial is for Yamaha petcocks but lessons apply to Kawasaki as well  Rebuilding vacuum operated petcocks
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Claude., Wookie58
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
09 Jan 2023 20:03
#878702
By MY experience, ALL eBay petcocks leak.
  • Michel3007
  • Michel3007's Avatar
10 Jan 2023 00:15 - 10 Jan 2023 00:17
#878703
I had the same problem as you do, Claude, for my KZ750 LTD H2.
Petcock leaking despite a replacement kit for the rubbers and diaphragm and several cleanings of the inside of the petcock.
I then decided to buy a suzuki petcock that somebody recommended on the forum. It worked well but I was a bit annoyed at not being able to rescue the original petcock.
Recently, I let the old petcock with new rubber parts seating in a bowl of fuel for a night and tested it the next day.
I guess that the rubber swelled because the petcock now works perfectly ! I put it back on my tank and it has not been leaking a drop since.
Maybe give it a try
And do follow the tutorial posted by ThatGpzGuy, I did exactly that, cleaning as best you can all the parts to make sure it seals properly.
KZ 750 H2 LTD 1981
GPZ750R1 1982
Last edit: 10 Jan 2023 00:17 by Michel3007.
  • Claude.
10 Jan 2023 06:12
#878707
Good reading! I did some of the steps but not all. I will redo the rebuild including those steps. Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • Claude.
10 Jan 2023 06:14
#878708
So sad that the chinese can't reproduce a good design... If they were half the price with good design instead of one quarter the price with a bad design, they would be a much better option.
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
The following user(s) said Thank You: blipco
  • Claude.
10 Jan 2023 06:16
#878709
Maybe give it a try
Rubber swelling... Didn't thought at this! Will try it for sure before putting it back on the fuel tank. Thanks for sharing!
Now I'm wondering if the eBay units could seal after a one day "fuel bath"... Hmmm...
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • Nessism
  • Nessism's Avatar
10 Jan 2023 07:44 - 10 Jan 2023 07:46
#878715
I rebuilt the petcock for my 750E, using OEM Kawasaki parts, and it works perfectly.  Kawasaki doesn't sell a "kit", you have to order the parts separately, but everything seems to be available.  Obviously, each petcock is different, and I'm sure the parts support is spotty at best across different models.
[img
P1010520 by nessism , on Flickr
Last edit: 10 Jan 2023 07:46 by Nessism.
  • Claude.
10 Jan 2023 10:22 - 10 Jan 2023 14:07
#878719
...Obviously, each petcock is different, and I'm sure the parts support is spotty at best across different models.
I'm always wondering why they are different from one model to another. As an example, p/n is different between my KZ750 and my 1000J. But by looking at them, they are virtually identical. I assume the height of "reserve" built in the plastic "filter" could be different but everything else looks to be interchangeable. I also think, that event if both have different p/n for the diaphragm, both seem to have the same dimensions and, theoretically, should work the same exact way. So, why make the diaphragm different??
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 10 Jan 2023 14:07 by Claude..
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
10 Jan 2023 12:25
#878722
I can think of a couple of reasons for differences in parts. First has to do with supply of the parts in question and the cost of said parts.  Secondly it may of been that a change in design had to so with some type of improvement or at least preceived improvement.  But I would think it had more to do with cost and supply.  But what do I know?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Claude.
10 Jan 2023 14:15 - 10 Jan 2023 14:16
#878729
Just finished rebuilding "again" the petcock.
As written in the link posted by ThatGPzGuy (thanks again!), I polished the o-ring seats sanded (with 600 grit) some mating surfaces and shooted silicone spray on the rubbers.
The assembled part is now soaking in a jar filled with gas. Will install it back later, hopefully this week.
Only thing I noted is that the "vent" built in the plastic plate (over which the diaphragm but be installed) can not be installed on the lower edge. Because of small pins molded on the plate and small holes present in the casting, the only way the vent can be installed is on the lower half of the read edge. My other spare petcock (that I believe being from a 1000J) is also assembled that way.
Thanks again for every comment!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 10 Jan 2023 14:16 by Claude..
  • Injected
  • Injected's Avatar
10 Jan 2023 14:20 - 10 Jan 2023 14:25
#878730
You can order a OEM replacement direct from any Kawasaki dealer - see below for the PN (this example is a online reseller) :
www.cmsnl.com/kawasaki-kz1000p24-police-...assy-fuel_510231375/
Or another example from a online reseller :
www.z1enterprises.com/petcock-kz1000k44-...0-kz650h-kz750h.html
They are a bit expensive but they are made in Japan, and you can get the repair parts from Kawasaki Canada going forward.
Stay away from made in "China" petcocks because you can't reliably get replacement parts.
Kawasaki used a lot of different style petcocks over the years, they look similar but there are internal differences so these "rebuild" kits out there are hit or miss - mostly miss :(
1978 KZ650B2 modified project
Last edit: 10 Jan 2023 14:25 by Injected.
The following user(s) said Thank You: sf4t7, Claude.
