Throttle Valve 1.5 small square
  • Fox
  • Fox's Avatar Topic Author
01 Jan 2023 11:27
#878416
Hello,
i have here a z1r carbs to restore but one thottle valve is too damaged on the bottom and need to be replaced.
When i look on the throttle valves i can see a small square on the bottom.
I have other kz1000 carbs and they have not the small square.
I have 2 questions :
1° what is the use of this square ?
2° can i replace this valve by a kz650 1.5 valve that look to have this square to.
3° If i choose to replace the 4 trottle valves by 4 kz10000 ltd valves that have not this square is it a problem ?
On the picture the square is on the top of the valve :
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Throttle Valve 1.5 small square
01 Jan 2023 11:59 - 01 Jan 2023 12:02
#878419
Mikuni use a square as their logo on their jets.
I wouldn't use anything other than genuine parts for such critical components as fuel monitoring.
Pilot jet size 15 (with a square) is stock for UK 650's. Don't know what is stock for a Z1r so can't say if its a straight swop or not.
The number is the flow rate. Smaller the number lower the flow.
Last edit: 01 Jan 2023 12:02 by Warren3200gt.
  • Nessism
  • Nessism's Avatar
01 Jan 2023 12:10 - 01 Jan 2023 12:10
#878420
Mikuni changed the slides a fair bit over the years.  For example, there are various type of 1.5 slides; some are silver anodized, and others are gold, some have a thick bottom and deep pocket for the needle, and others have a more shallow pocked for the needle.  The devil's in the details.
Last edit: 01 Jan 2023 12:10 by Nessism.
The following user(s) said Thank You: Fox
  • Fox
01 Jan 2023 12:17
#878421
Yes i know that but because some parts are the same like floats, pins, float bowls ... i try to find a solution without buy this new part that is expensive...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Nessism
  • Nessism's Avatar
01 Jan 2023 12:21
#878422
What square?  The notch in the side of the slide?  And if so, what notch?  There are two.
  • Fox
01 Jan 2023 12:25
#878423
The small top notch on the picture.
Not the logo not the slide :)
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
