Cr 29's
- seminole1
Cr 29's
12 Nov 2022 08:10
Any opinions on Cr 29's on a comp built 1075. Negatives and positives?
RETIRED TRUCK DRIVER 42 YRS.
Re: Cr 29's
12 Nov 2022 16:45
Depends on the build. If it is a fairly mild build, they should be pretty excellent. If it is a big port, high compression, radical cam build, they will be inadequate.
- Injected
Re: Cr 29's
13 Nov 2022 09:52Comp built? for what purpose?Any opinions on Cr 29's on a comp built 1075. Negatives and positives?
Not enough information given to reply with any suggestions or advice, please elaborate.
1978 KZ650B2 modified project
- seminole1
Re: Cr 29's
13 Nov 2022 11:38
Injected , per your enquiry. 1075cc street build. 205 PSI dome piston mtc compression. PSP 3x cams, ported intake and exhaust. Welded crank, 4-1 Vance Hines. APE springs. Earls 16 row curved oil cooler. Back cut trans. I'm sure I missed something. Full PSP build by Joe Hooper. Currently running 28mm Mikuni jetted, pods and Zed1015 air correctcorrector jets. K+N pods.
- Injected
Re: Cr 29's
13 Nov 2022 15:52 - 13 Nov 2022 16:01Thanks for the more comprehensive information.Injected , per your enquiry. 1075cc street build. 205 PSI dome piston mtc compression. PSP 3x cams, ported intake and exhaust. Welded crank, 4-1 Vance Hines. APE springs. Earls 16 row curved oil cooler. Back cut trans. I'm sure I missed something. Full PSP build by Joe Hooper. Currently running 28mm Mikuni jetted, pods and Zed1015 air correctcorrector jets. K+N pods.
Zed1015 may have more experience than me on this combination but I will take a stab at it.
You did not mention what head was on it or if it had oversize valves but it may not matter.
I believe the general rules use to be like this :
If it was a hot 1015cc you would want at least a 29 smooth bore.
If it close to 1200cc you would want at least a 33 smooth bore.
Your sort of in between so I would say the 31 CR Keihins may work for you, the 29 version may be a bit small for those cams/head.
The cheaper solution would be to bore the 28's to 30mm and open up the orifices where the fuel flows between the carb bodies. You also want to use the largest float needle valve assembly as that my also be a fuel restriction. WGcarbs was selling these assemblies but I don't see it listed on the web site.
We know the Mikuni VM carbs work very well and almost bog free, the same cannot be said about 33 smooths and 34 flats - they do have a bog but it takes a lot of effort to tune thru it.
You already have the air corrector jets so maybe expand on that and see if it likes it.
Last edit: 13 Nov 2022 16:01 by Injected.
- seminole1
Re: Cr 29's
14 Nov 2022 08:52
Forgot Dyna 2000 set half way between . Running too far advanced she pings.
- Injected
Re: Cr 29's
18 Nov 2022 06:57 - 18 Nov 2022 07:0138 degrees of total advance is a maximum suggested setting for these engines (for a drag race motor its only 2 deg higher)Forgot Dyna 2000 set half way between . Running too far advanced she pings.
On the street you run the chance of damaging your engine with maximum settings as race motors don't run for very long.
It may be a tiny less "snappy" but you have a ton of motor there for the street.
I am currently building a 1197cc KZ street motor and I think I will limit it to 36 degrees.
Last edit: 18 Nov 2022 07:01 by Injected.
- seminole1
Re: Cr 29's
18 Nov 2022 07:44
Injected, All response very much appreciated and any more welcome. I may be old but I still like to twist that "Loud Handle"
The following user(s) said Thank You: Injected
