Engine revs up high after cold start
- KZ650B_Joerg
31 Oct 2022 13:06
Hi,
quick question: Is it normal that my Z650B (VM24SS) at cold start with full choke revs up 1-2 seconds after start to over 3000 rpm? No trottle of course. Every time I need to reduce the choke quickly to keep the engine at a reasonable speed for warm up. It starts best with full choke when cold.
Apart of this everything is good with the engine.
Cheers
Joerg
Cheers
Joerg
- zed1015
Re: Engine revs up high after cold start
31 Oct 2022 13:10
Yes! That's normal.
31 Oct 2022 17:29 - 31 Oct 2022 17:30
As zed1015 mentioned, it´s normal. KZ 650/900 VM carbs has not a choke but an extra fuel enrichment cricuit that by pass the normal idle adjustment. It´s like an extra little carb running more fuel and higher idle during the cold start period against the condensation losses of fuel on the cylinder walls.
Last edit: 31 Oct 2022 17:30 by Scirocco.
- KZ650B_Joerg
01 Nov 2022 00:27
Thanks zed1015 and scirocco! Yes, I saw the choke plunger during carb cleaning which bypasses idle mixture.
So I keep my left hand near the choke lever at cold start.
Cheers
Joerg
Cheers
Joerg
- zed1015
01 Nov 2022 00:49To be accurate the choke doesn't bypass the pilot circuit/idle mixure.Thanks zed1015 and scirocco! Yes, I saw the choke plunger during carb cleaning which bypasses idle mixture.
Cheers
Joerg
It just adds more fuel for cold starts.
The pilot circuit remains active at all times and adds to the entire fuel curve.
The overall jetting is a stack up of all the fuel circuits.
- willemZ900
- Z1B 4 ever
01 Nov 2022 02:12
Have always the same with my VM29 smooth, is normal behavior for VM carbs.
