Carb change on kz1000 st 1980
- Armahammer
23 Sep 2022 10:59
Hi I am refurbing my carbs on a 1980 st to my disappointment I found they were 26mm mikunis , I believe they should be 28mm they have a Acc pump, would this make a significant difference to performance,and is it possible to swop out the 26mm parts into some 28mm carbs .
- zed1015
Re: Carb change on kz1000 st 1980
23 Sep 2022 15:09
Yes! They should be 28mm and the 26's will slow it down a little.
Many parts are interchangable but it all depends what parts you mean.
You cannot fit the pumper parts into non pumper bodies unless you machine the bodies for the nozzles etc.
Non pumper 28's will work well.
The following user(s) said Thank You: Armahammer
- Armahammer
24 Sep 2022 11:09
Hi was thinking of changing the float bowls from the26 mm. to 28mm carb bodies and would need to replace the inlet rubbers .are the float bowls interchangeable?
- gd4now
- Denco where did you go?
24 Sep 2022 13:05
I think it would be dependent upon which set of vm26ss carbs and which set of vm28ss carbs you have.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
24 Sep 2022 14:14
If I'm not mistaken, the rubber boots on the head are the same between the 26 and 28 carbs. I'm not sure about the airbox boots, though.
- zed1015
24 Sep 2022 15:12 - 24 Sep 2022 15:13Bowls will swap. You just won't be able to use the pump function.Hi was thinking of changing the float bowls from the26 mm. to 28mm carb bodies and would need to replace the inlet rubbers .are the float bowls interchangeable?
Carbs are externally dimensionally the same so no need to change inlet or air box rubbers.
Last edit: 24 Sep 2022 15:13 by zed1015.
24 Sep 2022 17:17
Unless you plan to go 140 mph I wouldn't worry about the 26 mm carbs. I swapped my 28's for some 76 26's on my 1980 KZ1000 LTD and they perform just fine, although I've never taken the bike over 100 mph.
- Armahammer
25 Sep 2022 05:49
Thanks guys for the very useful info will let you know how i get on.
