1976 KZ900 Mikuni VM26 - VM28 ??
- mrmach5
21 Aug 2022 07:16
Question , are you able to run the 73-75 Mikuni VM28 carbs on a 76 originally equipped with VM26's. And if so and effects, or changes that need to be made?
Thanks in advance!
Thanks in advance!
- krazee1
Re: 1976 KZ900 Mikuni VM26 - VM28 ??
21 Aug 2022 07:40
The short answer is Yes, jetting requirements will be determined by your bike and what modifications have been done to it.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- mrmach5
21 Aug 2022 07:45
The bike has the stock airbox and stock reproduction 4 into 4 exhaust .
- Moose1800
21 Aug 2022 08:34
I'm running VM28's on my 76 900 ltd which had VM26's as stock and noticed the fuel petcock is very close to the top of the carbs.
21 Aug 2022 08:36
Well at that point you should use the factory settings. Basically you will have a Z1 engine in a Kz frame. Do you have ‘73 to early ‘74 with a large drain in the bowl, or the later with the small brass drain. Once we know that we can get you stock settings. You need to clean the carbs and document, jet needle and it’s clip position, needle jet size, pilot and main jet, and slide cutaway. Then you can install as necessary to get back to factory settings.
- zed1015
21 Aug 2022 10:09 - 21 Aug 2022 10:10
The early two bolt top vm28sc carbs will perk up the motor over the 26's due to the larger venturi but the early SC carbs are not as good as the later 26/28ss carbs for maintaining carb sync so wouldn't be my first choice unless i had to use them.
All the 903/1015 carbed motors are basically the same engine with differing carbs specs only needed for the different exhaust and airbox design of a particular model.
Fitting the sc carbs to your 76 with airbox and 4x4 should need very little if any changes to the stock jetting apart from some minor tweaking.
Last edit: 21 Aug 2022 10:10 by zed1015.
