Carb cleaner/ brake cleaner are they inerchangable
- ckahleer
20 Aug 2022 16:12
I have 5 spray cans of brake cleaner on the shelf, but have just run out of carb cleaner. (Both the Walmart Super Tec stuff). Is there any harm in using brake cleaner to clean carbs? Will it be less effective?
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
- gd4now
- Denco where did you go?
Re: Carb cleaner/ brake cleaner are they inerchangable
20 Aug 2022 16:33
IMO the brake cleaner is more likely to harm rubber parts like o-rings than carb cleaner will. But here are some quick links via the internet you may want to read.
pj1.com/blog/brake-cleaner-and-carburetor-cleaner/
www.sanvochemicals.com/break-cleaner-vs-...r-their-differences/
gearslap.com/carb-cleaner-vs-brake-cleaner/
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- ayeckley
20 Aug 2022 17:52
In my experience if the carbs are properly disassembled then brake cleaner will be more effective at removing varnish that carb cleaner doesn’t touch. I agree that it will degrade most soft goods (except maybe Viton). I don’t understand why the linked article suggests that brake cleaner will somehow introduce contamination.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
20 Aug 2022 18:08
Break cleaner didn´t harm any rubber parts, o-rings, caliper dust seal or boots and evaporates very quick!
20 Aug 2022 19:04
Chlorinated brake cleaner will melt rubber while you watch. It is no longer available in California and other places. The non-chlorinated cleaners are not so aggressive on the soft parts. In my experience, good carb cleaner does a much better job on carburetors than brake cleaner does.
- Nebr_Rex
21 Aug 2022 05:20 - 21 Aug 2022 05:24Chlorinated brake cleaner will melt rubber while you watch. It is no longer available in California and other places. The non-chlorinated cleaners are not so aggressive on the soft parts. In my experience, good carb cleaner does a much better job on carburetors than brake cleaner does.
I agree, compaired to Berrymans B12 brake cleaners are weak sause.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 21 Aug 2022 05:24 by Nebr_Rex.
- ayeckley
21 Aug 2022 06:30
Hmmm. I wonder if I’ve been using very bad carb cleaner, or very good brake cleaner. I’ve got a gallon of very old Berrymans (from before the change in chemistry) and even that isn’t as good as the brake cleaner I’m using. I get mine from Menards (Ohio); there are Chlorinated and non-Chlorinated both available side by side on the shelf. It’s going to seem even odder, but I’ve found the non-chlorinated stuff to work better than the chlorinated.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
- Kelly E
21 Aug 2022 13:38
Non-clorinated brake cleaner doesn't hurt the soft rubber and plastic parts. It doesn't hurt the rubber caliper piston and slider pin boots. I even use it to degrease parts just before I paint them. As soon as it evaporates they are ready to paint. I have painted several bikes worth of parts after using non-clorinated brake cleaner without any problems. I use it to blast old petrified grease out of the handlebar control switches. It also works great for cleaning out all of the connectors on the wiring harness. We buy it two cases at a time.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
