cv bs34 are there any diaphragm needles available still, without buying a kit?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
24 Jul 2022 23:25
#870968
as far as adjustable needles go, anything available besides the dynojet kit
PO installed dyna s ignition w 2ohm coils and pod filters, 4 to 1 exhaust
wish po would've at least kept the air box smh
1982 KZ1100D1
  • zed1015
  • zed1015's Avatar
Re: cv bs34 are there any diaphragm needles available still, without buying a kit?
25 Jul 2022 00:52 - 25 Jul 2022 03:40
#870969
2ohm coils are wrong for use with a DYNA S .
They should be 3 to 5 ohms.
2 ohms will run very hot and fail.
What bike is this ?
I may have CV air corrector jets to help cure the off idle bogging that occurs with pods.
Fixed position needles can be adjusted using shims.
Last edit: 25 Jul 2022 03:40 by zed1015.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
25 Jul 2022 06:43
#870978
I am not claiming this is true of all carbs offered stock on the Kaw bikes, but in general only the bikes intended for the US market make use of the non adjustable needles .  As zed indicated the use of shims can be used for adjustment.  Often times the carbs on non US market bikes do make use of adjustable needles.  You may be able to locate these needles on non US locations selling parts..
I have not done any searching for them so do not mean to indicate there are any out there currently.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Gdailey2112
  • 82 KZ1100D1
25 Jul 2022 19:18
#871043
oops that was s typo, 3 ohm coils
1982 KZ1100D1
