Float setting BS34 book says 18.6mm but
- Gdailey2112
- 82 KZ1100D1
14 Jul 2022 16:58
i want to use the clear tube method but what size or gauge of clear tube works best?
1982 KZ1100D1
- Gdailey2112
- 82 KZ1100D1
Re: Float setting BS34 book says 18.6mm but
21 Jul 2022 14:39
So it turns out that with my particular set of BS34's, the float height is supposed to be set at 22.4mm whereas my manual says 18.6mm. And after searching this forum was able to see some confusion as to what is correct. Clear tube check is the true blue way to be 100% sure. This problem is solved! Thanks to everyone here!
1982 KZ1100D1
