#2 Cylinder Not Firing - Finally, a Solution!
- jekyllman
29 Jun 2022 13:48
I've been plagued for almost a year now trying to sort out why my #2 cylinder wouldn't fire. Everything I tested checked out. Spark seemed fine. Voltages at ignition coils is fine. Voltage along the entire circuitry is great. Compression on all cylinders is fine. Balanced the carbs with vacuum gauges within a couple mmHg. Cleaned the carbs. Checked the float height in the carbs. Ran ethanol free fuel. Valve clearances are all in spec. Points/timing all adjusted and in spec. Timing chain checked and double checked while replacing valve seals. Checked for vacuum leaks at carb boots. Should I go on? I bugged many of you over the past year searching for solutions and possible causes and you were all very willing to help (thank you!). But I've finally found what I believe to be the cause!!
:drumroll:.........the accelerator pump diaphragm (specifically, the vacuum sensor) was trashed. That was it. I took it apart and it was completely porous. I bought a rebuild kit and after installing and testing, not only did all four exhaust headers heat up to within 10 deg F but after a quick test ride it sounded beautiful and it pulls when you hit the throttle!! It idles correctly and everything! It's a miracle!
So, the morale of the story is to check your accelerator pump diaphragms if you have issues with the cylinder that the pump is on. Hopefully this saves someone else a year of stressing and frustration. The good news is that I now know how to diagnose basically every part of the ignition on my bike.
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
The following user(s) said Thank You: TexasKZ, Street Fighter LTD, SWest, Mikaw, Scirocco, howardhb, Wookie58, southKZ
- gd4now
- Denco where did you go?
Re: #2 Cylinder Not Firing - Finally, a Solution!
29 Jun 2022 19:19
Glad to hear your finding and fixing the troubling issue. This should just add to the huge amount of fixes the data set that is here provides.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- southKZ
11 Jul 2022 01:07
Well done! Maybe this will be the solution for my kz400 G3 issue as I tried and tested everithing you mention.
The only thing I can't understand is the vaccum sensor you're referring to: I mean, diaphragms can be found (to the best of my knowledge) on carbs, tap-assy fuel, and master cylinder.
Where should I search for?
Thanks in advance!
Giovanni - Florence (Italy)
Thanks in advance!
11 Jul 2022 21:04
The KZ400 carburetors do not have that particular feature.
The following user(s) said Thank You: southKZ
