Float height cv34
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Float height cv34
22 Jun 2022 08:53
#869210
Hello whats the set of the keihin float cv34mm are supposed to be?! I want the measure from the carb and the top of the float .. not the gas tube method of it’s possible.
thank you so much
maxime
Kz750e 1980
  • Nessism
  • Nessism's Avatar
Re: Float height cv34
22 Jun 2022 16:44
#869225
The gas measurement method is the only proper way.  And unless your float needles are in very good shape, I recommend changing them for new.  Either OEM (expensive) or Keyster (the best of the aftermarket needle makers.)
  • Maxbou92
22 Jun 2022 18:14
#869229
Can you explain me how to do that?!  Fill up the carburetor and open the drain valve.. I understand that, but do I need to write a measure on the tube for be sure the gas don’t exceed the mark?! Or the gravity do his job and I only need to check the 4mm behind the bowl ?! Thank you again
Kz750e 1980
  • TexasKZ
  • TexasKZ's Avatar
22 Jun 2022 20:08
#869231
The procedure is well described in the factory service manual.
