Keihin cv34
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Keihin cv34
14 Jun 2022 10:28
#868781
Hello, I wanna know whats the function of the small one Main jet of The Cv34mm ?! Its a stock one 62.. I understand the pilot and Needle Jet (2nd Main jet) function.. but whats the function of the small one just under the secondary Main ?! do I need to play with it or just change the secondary.. Thank you
Kz750e 1980
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: Keihin cv34
14 Jun 2022 14:56
#868793
Starter jet, pilot jet, main jet.
Fuel for the bike to start (catch).   Fuel for the bike to idle.   Fuel for the bike to run
  • Nessism
  • Nessism's Avatar
Re: Keihin cv34
14 Jun 2022 16:58
#868803
The CV34's have a three stage jetting system: pilot, primary main, secondary main.  Each comes in at different times, depending on the engine's air demands.
  • Maxbou92
Re: Keihin cv34
15 Jun 2022 04:34
#868822
Yes I know they had a time for each other! !  0-1/4 is pilot, 1/4-3/4 is Needle, 3/4- Cut off is main jet(needle jet) .. thats right?! If yes, when the small one main is active ?!
Kz750e 1980
  • Nessism
  • Nessism's Avatar
Re: Keihin cv34
15 Jun 2022 18:12 - 15 Jun 2022 18:13
#868858
I'm not sure if your description is exactly correct, but clearly, all the jets are active at some point in the bike's running range.
If you are looking for a short cut when running pods, then a Dynojet kit is the answer.  And get real K&N pods.
Last edit: 15 Jun 2022 18:13 by Nessism.
