Kz750 Keihin tune
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Kz750 Keihin tune
02 Jun 2022 14:50
#868065
Hello everyone, I just bought a Kz 750 1980, I rebuilt the bike and the engine 0.5 oversize, mild porting and milling the head to have 10 10.5/1 compression.. I have pods filters and stock 4-1 exhaust
can you Guys tell me what size of jets you will use for this setup (Keihin 34mm diaphragm)
thank you very much
Kz750e 1980
  • TexasKZ
  • TexasKZ's Avatar
Re: Kz750 Keihin tune
05 Jun 2022 06:49 - 05 Jun 2022 06:56
#868266
This should get you in the ballpark.
kzrider.com/forum/3-carburetor/484663-po...d-exhaust-re-jetting
If you are using cheap filters, then you may never get the carbs to work correctly. Some actually block the small air intake ports around the mouth of the carburetor. Name brands like APE, K&N and Uni will be fine.
I must admit that I do not understand why you would spend all that money and time getting the engine to intake better and then choke it down with the stock exhaust.
Last edit: 05 Jun 2022 06:56 by TexasKZ.
  • Maxbou92
05 Jun 2022 07:05
#868268
Thank you, I want to order 4Pod Foam Uni filter, but Im waiting of the dimension.. I know they are 2” inlet(perfect for keihin) and 4”long.. but do you know if they will have enough place to be side by side?!!
Im planning to let the 4-1 exhaust, because the last guys has broken the muffler and is now Inside Wide open !! What will be the difference of order another 4-1 exhaust at 3-400$ ?again,  Thank you very much
Kz750e 1980
  • zed1015
  • zed1015's Avatar
05 Jun 2022 07:12
#868269
See attached link for recommended main jet increases on stock motors with air corrector jets fitted for pod use which is 150 across the 750 range.
For the comp increase you should jet a little higher and work down.
As TexasKZ previously mentioned retaining the stock exhaust won't help with getting the best out of your set up.
Air corrector jet kit. CV Carbs . Kawasaki Z650,Z750L3,Z750 CUSTOM,GT750,GPZ750 | eBay
  • Maxbou92
05 Jun 2022 07:20
#868271
Kz750e 1980
  • Maxbou92
05 Jun 2022 07:31
#868273
All right, I will go see this topic. Thank you so much
Kz750e 1980
