Push and Pull Cables
  • Rick H.
  • Rick H.'s Avatar
Re: Push and Pull Cables
04 Jun 2022 05:48
#868190
Be aware that not all "return springs" have the same amount if tension.  I ordered a couple of springs for my KZ from the same place and they had differing rates of tension.  I ordered another one from a different supplier and it was different from the other 2 that I had.  I went with the lightest tension rate.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Lebowski
  • Lebowski's Avatar Topic Author
07 Jun 2022 03:15
#868402
Alright. I made a few adjustments. Thanks for the tips and the better understanding of what the "push" cable is intended to do. Not a fan of that particular cable.
1. Adjusted the pull cable according to manual, so it has a little slack and play.
2. Greased the housing and under the throttle. This had the biggest impact. It definitely feels smoother when I throttle.
3. I did not replace the spring. The throttle pops back in about 1 second. Does this seem okay? I am tempted to just buy a new carb spring to have peace of mind about it.
thanks
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
07 Jun 2022 04:15 - 07 Jun 2022 04:16
#868404
I think you are good for a new spring, long as there is a relative snap back you are grand, when we are driving we roll the throttle. as long as things are effort free in the return the rev's wont be prolonging when they shouldn't be and in the worst case if you have to take your hand off the throttle it will go back to where its supposed to be.
Last edit: 07 Jun 2022 04:16 by kzstreetfighter71.
The following user(s) said Thank You: Lebowski
