Left side carb over flowing after shutting bike off.
- Qsmothers3
09 May 2022 04:02
Please help! My 1982 kz440 started leaking a small amount of fuel out of the left side overflow tube when I shut it off. It only happens when the bike is off and not while it's running. I have the floats adjusted to spec. No cracks in overflow tube. I'm lost.
Re: Left side carb over flowing after shutting bike off.
09 May 2022 04:31
Check your float valve to see if it closes and seals properly.
09 May 2022 04:59
Sounds like the petcock isn't shutting off fuel like it should when the engine is off. Also, the fuel level is too high in the leaking carb, most likely from a sticking/dirty float valve. Checking float level isn't good enough, you need to check fuel level in the bowl.
- badgb21
10 May 2022 09:16
As others have stated, it's most likely a sticking float valve.
Modern fuel gum or crud can often cause it.
Before you go ripping the carbs apart;
Check petcock filter and ensure it's clean.
Be sure you have good fresh fuel in the tank.
Consider fitting a fuel filter in the fuel line, depending on the room you have under there, but get a quality one.
Should be quite an easy job.
For a while when you finish riding, turn the fuel off and let it run a short time, then shut it off. This will reduce fuel in the system and minimize the overflow.
If you have a vacuum pet cock, you may be limited to one system's worth of fuel that will flow out.
You may well find this problem will clear in time and fitting a filter may stop it from happening again (or until it's gum, then they'll need to come off for a clean)
Also park as upright as possible and side stand lean may not help.
Good luck and hope it passes.
KZ900 A4 1976
KZ650 B2 1978
KZ650 B2 1978
