Overflow
  • Pattenrd
  • Pattenrd's Avatar Topic Author
Overflow
01 May 2022 16:09
#866497
Purchased and installed air corrector on vm 26 carbs on early 78 KZ1000b  benchnched them with .028 wire  put back on motor turned gas on gas pours out overflow  what would cause that floats seem fine float bowls  have numbers 1&3on inside does that mean anything  any help would be appreciated  thanks
  • Nessism
  • Nessism's Avatar
  • Away
  • Nessism
  • Nessism's Avatar
  • Away
Re: Overflow
01 May 2022 16:14 - 01 May 2022 16:15
#866500
Float valves are not sealing.
Edit: I posted once, but this message showed up twice.  Sorry.
Last edit: 01 May 2022 16:15 by Nessism.
The following user(s) said Thank You: Pattenrd
  • zed1015
  • zed1015's Avatar
  • Away
Re: Overflow
01 May 2022 16:27
#866501
Original worn float valves can be temperamental when they have been disturbed .
They usually settle once a bit of fresh fuel has passed through them and a few taps on the bowl can help them seat.
  • Pattenrd
Re: Overflow
02 May 2022 03:07
#866525
Thanks for the quick reply  I removed the carbs and checked the floats  cleaned everything with carb cleaner going to hook fuel lines up and see what happens
  • Pattenrd
Re: Overflow
04 May 2022 16:34
#866628
Cured overflow problem  after starting bike still runs pretty rich carburetors had 120 mains and 17.5 needle vm26 carbs book says 105 mains 12.5 needle  kn pods and 4 into 1 should I run for octane on fuel any information would be appreciated thanks
  • TexasKZ
  • TexasKZ's Avatar
Re: Overflow
04 May 2022 20:30
#866636
Have you checked the fuel level in the carbs using the clear tube method?
Unless you have aftermarket high compression pistons, the engine does not need additional octane. Use what the owners manual and service manual recommend. Using higher octane is a waste of money.
  • zed1015
  • zed1015's Avatar
  • Away
Re: Overflow
04 May 2022 23:44 - 05 May 2022 00:32
#866641
Mains are too big.
With the air correctors you only need to a couple of sizes or so up from stock so 110-115 max.
ALL other carbs setting should remain stock, especially pilot jets and needle position (3rd / middle groove).
Last edit: 05 May 2022 00:32 by zed1015.
  • Pattenrd
Re: Overflow
05 May 2022 04:08
#866645
Looks like I'll be taking them off again and putting in smaller mains I have 112.5  and ordering stock needles  getting to know my Kawasaki better thanks for the help again
  • zed1015
  • zed1015's Avatar
  • Away
Re: Overflow
05 May 2022 05:19
#866647
Stock needles ? Do you mean pilot jets ?
  • Pattenrd
Re: Overflow
05 May 2022 09:19
#866653
Yeah
I mean pilots  ordered stock ones this morning and will be taking carbs off when I get them  getting pretty good at it    thanks
  • Pattenrd
Re: Overflow
13 May 2022 04:32
#866995
Installed stockpilots and 112.5 mains bike run real good now  thanks for the help
