Where to buy KZ1000 float valves?
- DOHC
- Those Doe-Hawks really go!
22 Apr 2022 21:26 - 22 Apr 2022 21:49
I'd like to buy genuine Mikuni needle and seat float valve assemblies to rebuild my carbs. Specifically 1978 KZ1000 Z1R VM28 carbs, but I think all the 77-80 KZ1000 used the same part.
Last time I did this I managed to get lucky and find a set relatively cheap. This time I'm not having as much luck.
I'm trying to figure out if there is an alternate part number that I can substitute. Here is what I have so far.
OE 16030-027: Partzilla says it's NLA from Kawasaki. JetsRUs lists it as Sudco 007-966 for $28.51 each.
The parts I found last time were Mikuni VM26/26-2.3. As far as I can tell these are the same as the OE parts. But Mikuni VM26/26-2.3 is nowhere. I can find Mikuni VM26/26-2.5 and Mikuni VM26/26-2.0 from Summit. They are better, at $16.99 each.
It looks like Suzuki used the same part on the GS1000. Suzuki 13370-18111. Partzilla lists these for $47.25.
Any chance the VM29 smooth bore needle/seat fill fit in a KZ1000 VM28? That seems to be P/N N122/032-2.5 and Summit carries that one for $13.99
Can I get away with a 2.5 (larger) or 2.0 (smaller) seat? I figure if the VM29 used a 2.5 the VM28 would probably be fine with one? What's 1mm.
Nessism, I'm looking at you... Where do you get your float valves?
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 22 Apr 2022 21:49 by DOHC.
- daveo
Re: Where to buy KZ1000 float valves?
23 Apr 2022 05:29
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
23 Apr 2022 05:42 - 23 Apr 2022 05:50
You can use 2.0's just fine, assuming you are not going to be racing. I typically get them from Dennis Kirk, but their price is $21.55 currently (it's gone up.)
Keyster brand is 2nd best. Sirius sells kits for cheap. I get the cheapest VM26 kits they sell, since the float valves and gaskets are all the same. www.siriusconinc.com/
Edit: You can also use the viton tipped version. I sometimes wonder if these would be even better at sealing.786-15005
Last edit: 23 Apr 2022 05:50 by Nessism.
23 Apr 2022 09:11
- DOHC
24 Apr 2022 10:47I should have been more clear. Where do I get cheaper float valves. I started with JetsRUs and ordered a bunch of other parts, but I wasn't exited about paying $114.04 for float valves.Mikaw post=866003https://jetsrus.com/individual_parts/007-966_su.html
Nessism post=865992You can use 2.0's just fine, assuming you are not going to be racing. I typically get them from Dennis Kirk, but their price is $21.55 currently (it's gone up.)
I found another thread where you recommenced the 2.0 as a replacement for the 2.3. Why do you prefer the 2.0 over the 2.5? I'm assuming the orifice size limits how quickly fuel flows into the bowls, but I don't have a good sense for what practical difference the size would make assuming it's not starving at WOT. Does a smaller hole make it easier to maintain a consistent fuel level? The Mikuni VM tuning manual doesn't have anything at all to say about float valve sizes.
That's a good idea. I should have done that instead of buying individual o-rings. Also, it looks like cycleorings.com is no longer in business?
Thanks for pointing that out. I hadn't noticed that the 786-15005 seats were the same dimensions. Does that retaining clip on the needle fit over the tang on the float? It looks like these are a bit cheaper than the VM26/26 at Summit. They are listed for $14.99.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
24 Apr 2022 14:44
Cycleorings.com closed down. The owner got sick and didn't have the energy to deal with it. You can get O-ring kits off ebay, though. Quite cheap.
I've used the 2.0 valves because they flow a little slower. I can't imagine anyone taking one of these bikes to the race track anymore, so draining the bowl shouldn't happen. That said, the Keyster 2.3's work fine for the most part. They have a stronger spring in the needle compared to K&L float needles, for example.
The clip keeps the needle in the seat, it doesn't loop over the float tang. I don't think it's strictly necessary, and many float valves don't use them.
