2nd carb barfing fuel
- xstreamcanadian
14 Apr 2022 18:08
The 2nd carb over from the choke (left side) seems to be drooling fuel. I had these carbs totally rebuilt from the guy in Texas, but they have sat around a bunch of years before seeing any fuel.
It seems to run pretty well, but obviously gas coming out of the pod isn't ideal. Its not a tonne but its present.
Also, does it matter which port I take for the vacuum peacock? I have a choice of two
it's a 78 kz650, rejetted(by rebuild dude) , pods, 4 into 1.
It's very very close to being on the road. First road ride today, seat less and no back brake but it was awesome. (Driveway tour not road) hasn't seen pavement since 1986.
It starts and runs and idles well BTW
Re: 2nd carb barfing fuel
14 Apr 2022 18:43
Have you checked the fuel level in the carbs?
Could be a dirty or failed float valve and failed petcock.
It does not matter which carb the petcock line goes to. The other vacuum ports should be capped.
The following user(s) said Thank You: xstreamcanadian
- xstreamcanadian
14 Apr 2022 20:06
Petcock is new and seems to work well. How would I check fuel level in carbs?
14 Apr 2022 21:06How would I check fuel level in carbs?
The procedure is in the factory Kawasaki service manual, which is available for free download here in the Articles storage area.
- xstreamcanadian
15 Apr 2022 07:41
i was reading that the #2 will overflow if the diaphragm in the petcock is bad,on bikes with the accelerator pump, but mine does not have the pump. I rebuilt the old petcock, but now im wondering if i put it back together wrong or something. It doesnt have an 'Off' it has on, prime and reserve. Which I found odd. I have three kzs, two in parts, so maybe i used the wrong one?
- rstnick
15 Apr 2022 07:52 - 15 Apr 2022 07:53
The vacuum petcocks can leak gas down the vacuum tube into carb #2.
Happened to me, flooding it.
Now my petcock wasn't new, and the diahpram was leaking.
Nothing to do with the accelerator pump (my model doesn't have accel pump).
No OFF position on the vacuum petcocks.
I bought a new petcock from Z1Enterprises, made for a Suzuki, with 44mm spacing.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 15 Apr 2022 07:53 by rstnick.
- xstreamcanadian
15 Apr 2022 08:45
I bought one as well, it came with an adapter plate and that part fits, but the petcock itself sits into the elongated oval just enough to need it to be reamed out round in the middle. So i didnt use it. I go the diaphragm rebuild kit,it doesnt leak overnight.... Ill try it again and see what happens. I stupidly left it on prime the first night i got it running and came back to a garage floor covered in fuel. DOH! Im scouring ebay etc right now. My bike is an SR, and I hate that tank, so I used a tank from my 77 kz650. So its that kind if that makes sense.
- gd4now
- Denco where did you go?
15 Apr 2022 10:41
OK I assume you have the stock vm24ss carbs on the bike. You posted that you have 2 ports to connect the vacuum petcock to. There should be 2 ports on carb #2 (left to right as you sit on the bike) the one that is on the engine side of the carb is the one that should be connected to the petcock to provide vacuum to the petcock, The other port located closer to the intake side of the carb provides a vent for the fuel bowl.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- xstreamcanadian
18 Apr 2022 08:29
Im changing out the petcock today, with a more simple on/off/res non vacuum one. I used fuel friendly Aisin sealer on the threads of the 3/8 npt petcock and also the mounting bolts. I dont want a shop full of gas again. Thanks for the insight. I rebuilt the entire old vacuum one so I either messed that up or ...? looking forward to a non gas soaked test ride. I found that the #1 and #2 were just pouring gas after I shut the engine off. Especially on the side stand. Pulling the fuel line off the carb assembly it was just free flowing like crazy, on all three settings.
cheers
cheers
