Dumb Question. Carb adjustment screws.
- ShaneDude
- Banned
18 Mar 2022 13:13
1977 Kawasaki 750B Twin. I dont have the manual. Never had to bother adjusting the carbs. where the hell are the adjustment/richening/lean screws? lol
Re: Dumb Question. Carb adjustment screws.
18 Mar 2022 13:35
Partzilla has parts diagrams. Look up your bike, then go to the carbs tab.
18 Mar 2022 19:16 - 18 Mar 2022 19:17
Service manual. You might be surprised at what is lurking in the Filebase and Articles sections of KZR.
www.kzrider.com/modules/ServiceManuals/K...l%20KZ750%20Twin.pdf
Last edit: 18 Mar 2022 19:17 by TexasKZ.
- ShaneDude
- Banned
18 Mar 2022 19:29
I found a free PDF of the manual not long after I posted that. I found the pesky pilot screws. One spark plug reads lean, and the other is just a little dirty, but not quite fouled. Need to adjust. changed the plugs and coil just in case.
19 Mar 2022 07:06
Was there a reason to suspect the coil? Did you get one with the proper resistance?
Have you checked the fuel level in each carb? Are the carb holders old and cracked? Has the bike been parked for an extended amount of time ( months or years)?
