KZ550 TeiKei TK-22 Bogging
  • KZ550C3NO
  • KZ550C3NO's Avatar Topic Author
14 Mar 2022 22:30
#863813
Hello
I have a KZ550C3 LTD 1982 model.
It has a 4-1 exhaust with original airbox
What mainjet and pilot jet do you recommend?
it is now a mainjet on #90 from earlyer owner.
It is bogging when driving, especially when full trottle and is hard to start when cold, when hot starts in 1 turn no problem.
  • martin_csr
  • martin_csr's Avatar
Re: KZ550 TeiKei TK-22 Bogging
15 Mar 2022 07:04
#863825
KZR member loudhvx may have the info on his Motorcycle stuff page. see links in his signature of any of his posts. His page has tons of info about the KZ550 & TK22 carburetors.
  • hardrockminer
  • hardrockminer's Avatar
15 Mar 2022 07:21
#863826
I had a 1981 KZ550, or actually my wife did.  It was a very cold starting bike, requiring at least 10 minutes of idling to perform correctly.  Is your bogging problem always there or is it only in the first few minutes of a cold start?
  • KZ550C3NO
30 Mar 2022 14:10
#864554
Hi
its bogging when hot, driving on both cruise and when trottle, probably midrange RPM
my RPM meter is broken.
it feels like its lean or something, i have ordered a OEM jetkit with #92 main jet so i did try to bore out the main i have now to 1mm just for experiment, it starts much faster and sound healthy at idle, but same problem in mid/top RPM
Found someone telling to try 1clip higher on needle, so im going to try that not
And after investigating on diameters and needle it looka like it is teikei TK-21 carbs
with specs same as 1981 kz550c1 west german
  • howardhb
  • howardhb's Avatar
  • God, I trust
31 Mar 2022 13:20
#864626
Check the ignition advance mechanism in the lower right hand crank-shaft end cover. The mechanism is "spring loaded" and should rotate freely and "snap" back to rest position.
lubricate it regularly.
H.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
  • zed1015
  • zed1015's Avatar
31 Mar 2022 14:58
#864632
With just an exhaust change you would barely need any jetting changes at all and if any then just a size up on the main and leave the pilots etc stock.
