Choke not working on kz650, why?
- mjjund
13 Feb 2022 10:28 - 13 Feb 2022 13:16
Hello,
I got my father in laws 1978 KZ650 out of storage since 1985 so being it was parked for 36 years I fully tore the carb apart and fully cleaned every part with a carb chem dip and it turned out great. The jets are clear and gaskets, o-rings replaced and put back together and when it's warm it runs really good on all cylinders.
But my problem is with cold starts, I have to crank it for a long time with battery charger to assist and eventually does slowly start to fire and run but the choke does not help at all and even seems to make it worse when I have choke engaged. And even when I have it running and engage the choke slowly, it did does not rev up even a little but starts to kill it too.
What could be the problem with my choke? I also don't quite understand how it works as it lifts a little plunger and opens a port but I can't tell where it should be pulling fuel from? These carbs were very gummed up, so maybe I have something still blocked? Any feedback would be appreciated.
Last edit: 13 Feb 2022 13:16 by Street Fighter LTD.
- zed1015
Re: Choke not working on kz650, why?
13 Feb 2022 14:46 - 13 Feb 2022 14:52
The brass tube on the carb body next to the float ( top right corner in your pic) is the fuel pick up for the choke.
There is a small hole in the end which may be blocked and another hole in the side of the tube at the very top as the tube enters the body , these both need to be clear.
Then also on the float bowl itself ( near your index finger in the pic) there is a chamber where the tube fits and gets it fuel supply from which is fed from the float bowl. There is also another small hole at the base of that which needs to be clear too.
Last edit: 13 Feb 2022 14:52 by zed1015.
13 Feb 2022 15:15
Your carb set is miles away form a correct rebuilt. Every internal removable part and port should be clean!!!
Did you or anyone else noticed like me, that your choke plunger lifters are mounted upside down???
13 Feb 2022 16:28 - 13 Feb 2022 16:30
Two things to check...
Regarding the 2nd photo, it's backwards; spray in the bottom of the choke passage, not into the choke pick up tube.
Last edit: 13 Feb 2022 16:30 by Nessism.
13 Feb 2022 17:33
- gd4now
- Denco where did you go?
13 Feb 2022 20:41
I agree with Ed on this one. But do want to say I have seen several different types/shapes of what I will call the lifters of the enricher/choke lever. I think the more interesting question is related to the shape of the old seal on the end of the plunger. I think there are others on here to provide solutions to this issue.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- ThatGPzGuy
14 Feb 2022 05:29You spray from that direction to flush out any blockage?
Before I assemble the carb bowl to the body, I fill the bowl with gas and make sure the passage fills with fuel. Every time.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- rstnick
14 Feb 2022 06:25
Welcome.
What is the jetting (main and pilot) of your carbs, and are you using the stock air box and air filter?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- blipco
- 2002 KZ1000P
14 Feb 2022 07:04
How many miles, do you need a valve adjustment?
What are the conditions of your carb holders?
And, as others have mentioned.. the filter and airbox.
- mjjund
23 Feb 2022 18:23
Thanks everybody for the feedback, a couple mentioned it that on a couple of the bowls the little hole that provides fuel for that tube were blocked. And on another one the hole at the end of the pick up tube was blocked. So cleaned those and not it starts right up on choke. Also thanks for the info that the choke lifters are flipped, I will correct that too.
