Carb rebuilding video?
  • Deuce
  • Deuce's Avatar Topic Author
13 Feb 2022 05:40
#862221
I'm going to attempt to rebuild the carbs on the 79 KZ1000 Shaftie I picked up last week.  Anybody have any suggestions for a good, comprehensive video to watch?
www.flickr.com/gp/162005819@N03/J055kUZ1a8
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Nessism
  • Nessism's Avatar
  • Away
Re: Carb rebuilding video?
13 Feb 2022 05:56
#862222
VM carbs like yours are easy to rebuild, other than the accelerator pump which can be fiddly.  The key to doing a good job is to take them apart and clean each body and all the jets in carb dip.  You don't need "carb kits" you need new float bowl gaskets and an O-ring kit, both of which is available on ebay.  Also, check the condition of the fuel tee and transfer tubes, and if the rubber is deteriorated budget for some new metal replacement parts.
This tutorial should help.   gsarchive.bwringer.com/bikecliff/images/vm_carb_rebuild.pdf
  • martin_csr
  • martin_csr's Avatar
13 Feb 2022 07:12
#862227
Carburetor work isn't that hard. The same thing is done 4 times on a lot of stuff & most parts only go back together one way, so it's kind of hard to mess up. Use good fitting tools to avoid damaging the brass bits. Don't order anything until you've got them apart & verified.  In many cases you only need to replace gaskets, o-rings & rubber bits. I've only done one set but it seemed easy. previously, I had removed the bowls & stuff under there. then did the full teardown.
  • hardrockminer
  • hardrockminer's Avatar
13 Feb 2022 08:04
#862230
As already noted, VM carbs are fairly easy to rebuild.  Most of the brass parts will be fine to re-use, with the following possible exceptions.
Needle jets - they protrude into the carb throat and can wear due to the sliding action of the needles.  If gas mileage is suffering this is one likely cause.  The needles and needle jets work together to restrict gas flow, and any wear will allow more flow than necessary.  I will normally replace both during a carb rebuild and have seen much improved fuel economy as a result.
Choke plungers - there is a gasket on the underside of the bottom of the plunger.  It is supposed to prevent leakage into the carb during normal operation but after years of use it stops sealing effectively and gas will bypass the gasket.  Trouble with the choke circuit is most noticeable when attempting to synchronize the carbs on the bike while running...it becomes very difficult to set properly.  Aed1015 is able to replace the gasket for a nominal cost.
  • Mikaw
  • Mikaw's Avatar
13 Feb 2022 10:04
#862247
Get some small containers and keep all parts with their original body. Main and pilot jets not to critical. But floats, float needles and seat and slide are important to keep with their original body. I use blue tape to make notes on the containers as to parts found bad and even to note which body and parts are soaking and the date and time they went in the soak. Tape can then be removed and the containers are ready for the next rebuild.
The following user(s) said Thank You: Nessism, Deuce, KZmarcel
  • Deuce
13 Feb 2022 15:27
#862275
Thanks guys.  I've got carb dip, carb spray and little tubs.  I did already order kits, based on what it's "supposed" to use.  Tools aren't an issue.
Isn't there an accelerator pump that should be rebuilt as well?
I dont know the last year it ran, but I'm guessing the early 90s, at best.  The carbs are from the donor bike, and that last ran in 87.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Nessism
  • Nessism's Avatar
  • Away
13 Feb 2022 16:10
#862278
The issue with carb kits is that they typically don't have all the various O-rings you will need.  And yes, replace the pump diaphragm.
  • Deuce
14 Feb 2022 08:39
#862329
This kit looks like it does.  I guess I'll find out when I tear into them, lol.  My problem is, I forget how to put something back together if it's more than a week or two after I take it apart.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Mikaw
  • Mikaw's Avatar
14 Feb 2022 10:49
#862341
Pictures, Pictures, and more Pictures
