Jetting
- Pattenrd
Jetting
12 Feb 2022 08:55
Just finishing up my 1978 kz 1000b project had no air box or exhaust went with k&n pods delkevic exhaust stock mikuni carbs any jetting info would be a great help runs now but plugs look lean
- zed1015
Re: Jetting
12 Feb 2022 09:01
You should fit air corrector jets -
Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis. - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
leave all other carb settings stock and go up a couple of sizes on the main jet..
- Flatblackobsession
Re: Jetting
13 Feb 2022 08:32
In my experience you'll want to go up a few sizes on both your idle and main jets, and adjust your air mixture screw accordingly once the bike is warmed up (trial and error, test riding the bike with a little screw driver in your pocket). I wouldn't worry about messing with the slide needles until you dial in the rest, as the other adjustments may get you where you want to go.
Re: Jetting
13 Feb 2022 08:39If he installs the Air Corrector Jets, then the pilot Jets need to stay stock.In my experience you'll want to go up a few sizes on both your idle and main jets, and adjust your air mixture screw accordingly once the bike is warmed up (trial and error, test riding the bike with a little screw driver in your pocket). I wouldn't worry about messing with the slide needles until you dial in the rest, as the other adjustments may get you where you want to go.
- Pattenrd
Re: Jetting
14 Feb 2022 04:01
Where do I buy air corrector jets and any other information about them would be appreciated thanks
Re: Jetting
14 Feb 2022 04:31 - 14 Feb 2022 04:32
Contact user Zed1015. See four posts above. He even put a link in his post.
Last edit: 14 Feb 2022 04:32 by TexasKZ.
- zed1015
Re: Jetting
14 Feb 2022 05:00As already mentioned all the info is in this link as posted above - Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis. - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's ForumWhere do I buy air corrector jets and any other information about them would be appreciated thanks
All the info you need is there for fitting etc plus comments and feedback from other forum members who use them.
Just PM me if you want a set or need any additional info that isn't covered in the above thread.
