1977 kz1000 a1 carb holder
  • Gdizard
  • Gdizard's Avatar Topic Author
  • 12/03/1954
29 Jan 2022 08:42 - 29 Jan 2022 08:44
#861362
CAN ANYONE REMEMBER DO THE CARB HOLDERS REQUIRE A CLAMP OR DOES THE CARB OUTLET JUST FITS SNUG ENOUGH WITHOUT A CLAMP?
THIS IS THE FRONT SIDE OF THE CARBS ATTACHING TO THE CARB HOLDERS THAT ARE ATTACHED TO THE HEAD.
Last edit: 29 Jan 2022 08:44 by Gdizard.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: 1977 kz1000 a1 carb holder
29 Jan 2022 09:22
#861365
Yes, they must be an airtight seal. There clamps available from the usual sources. Do not be tempted to use jubilee type clips as the will cut into the rubber and render the rubbers useless.
Z1000J2 somewhat modified!
  • Gdizard
  • 12/03/1954
29 Jan 2022 09:32
#861368
LIKE THESE SIR ?
  • Mikaw
  • Mikaw's Avatar
29 Jan 2022 09:36
#861370
Those come in two sizes, one fits the intake boot the connects the air box to the carbs. The other size fits the carb holders on the outlet side. Just make sure your ordering the correct one.
  • Warren3200gt
29 Jan 2022 09:36
#861371
Yes, just make sure they are for your engine/carb size. All z's use them. The smaller the engine capacity the smaller the clip dia.
