Need Mikuni Part or Info?
- z1kzonly
10 Dec 2021 08:03
Hello, I am looking for this small nylon bushing or whatever you call it?
These carbs are 29 smoothies.
Yes I could make one, I have no F's left to give. No extra play time lately!
I also lost 8 flathead carb mounting screws. I have black flat head 45° hex allens, but want OEM's for re-sale for a set of stock 76 26mm.
Figure I'd check here 1st before I go to the socialbook.
TIA
Marty in Buffalo
TIA
Marty in Buffalo
- willemZ900
- Z1B 4 ever
Re: Need Mikuni Part or Info?
10 Dec 2021 10:20
Hi Marty,
pic 1 VM24/532
pic 2 VM28/450 x 4
pic 3 C5=0614 x 8
good luck
pic 1 VM24/532
pic 2 VM28/450 x 4
pic 3 C5=0614 x 8
good luck
- z1kzonly
10 Dec 2021 15:08
Thanks Willy! But no pictures or parts fiche shows up?
10 Dec 2021 15:27
29 Smoothbore but should be the same. Don’t know where to buy
suzuki-classic.de/i/download/vergaser_vm29.pdf
- DOHC
- Those Doe-Hawks really go!
10 Dec 2021 17:53 - 10 Dec 2021 17:54
The sudco catalog shows the exploded diagram and all the part numbers for the vm29 x4. However, the specific parts you're looking for do not have an associated sudco part number, which suggests they are no longer available.
www.sudco.com/sudco_catalog_vol_38.html
See page 166 and 167.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 10 Dec 2021 17:54 by DOHC.
- z1kzonly
10 Dec 2021 18:44
Thanks Jim, yes I figured that. Was just hoping someone had some parts lying around. I did not react in time, but the OINK gang had a pile of carb parts up on auction. I could have Asked Brad Jr. to have swiped one out of that huge pile. But I missed out by a day. Oh well.
I'll just make one.
I'll just make one.
- Shankkole
12 Dec 2021 05:01
I can find one, and send it your way Marty. I was about to make some new ones as the old are quite brittle.The plastic /nylon parts from the past usually don't have a UV inhibitor so unless they get paint or oil on them they are victims of the sun. Be well
12 Dec 2021 17:30 - 12 Dec 2021 17:51
Evilbay item number
300539900259
124993640956
300539900259
124993640956
Last edit: 12 Dec 2021 17:51 by Mikaw.
The following user(s) said Thank You: z1kzonly, Nessism
- z1kzonly
13 Dec 2021 06:43I can find one, and send it your way Marty. I was about to make some new ones as the old are quite brittle.The plastic /nylon parts from the past usually don't have a UV inhibitor so unless they get paint or oil on them they are victims of the sun. Be well
Hi Brad, Thanks, I'll be in touch. I have a few leads. How's the trike coming? Stay safe and have a Merry Christmas & Great Holiday Season.
Thanks
Marty in Buffalo
- z1kzonly
13 Dec 2021 06:46
Hi Matt, Thanks for the research! Its cheap enough, Just looks like a stress crack blow up on smart phone pic??
I'll get to it. Busy time of year!
Stay Safe, Have a Merry Christmas & Holiday Season.
Marty in Buffalo
Marty in Buffalo
