CV34 diaphragms
- BobZ
CV34 diaphragms
22 Nov 2021 13:19
Ok...back into the carbs again. I swear I checked the diaphragms carefully each time I had them apart but lo and behold this time i find one with 3 little holes in it up near the top. I saw a website for JBM industries... about $20 each. It says you cut the plastic rings off completely and the new diaphragm installs without the rings. Is this the way to go or is there a better option? Not really concerned too much about the price. I'm going to replace all 4 regardless. Thanks.
Had I known I'd live this long I'd have taken better care of my Led Zeppelin albums
1983 Goldwing Interstate
1982 KZ750 LTD
1982 KZ750 LTD
Re: CV34 diaphragms
22 Nov 2021 14:56
I've got spare slides w/good diaphragms. PM me if you want one. I'd stay OEM instead of go aftermarket but that's just me of course.
The following user(s) said Thank You: BobZ
- BobZ
Re: CV34 diaphragms
22 Nov 2021 15:10
Actually I found a hole in another one.
1982 KZ750 LTD
1982 KZ750 LTD
- azman857
Re: CV34 diaphragms
22 Nov 2021 21:24
FWIW, I bought 6 of JBM's diaphrams for the 34 BS. 2 for my '80 XS 650SG and 4 for the carb rebuild for the 750 GPz engine. I've run the XS650 with them and work great.Where the cut out ring was, a thick "tire" to grab the "piston". There is no nub to keep the diaphram from rotating. Doesn't seem to be a problem in my experience. Very easy to install. Hardest part was removing that plastic ring!
The following user(s) said Thank You: martin_csr, BobZ
