1982 Kawasaki KZ 1100 A2
  • SmithDubs
  • SmithDubs's Avatar Topic Author
08 Sep 2021 18:34
#855022
Hey guys! I love these old motorcycles to death! The problem is I bought the bike from my father in law - they have very low elevation (300) compared to mine (3500). I can’t get a tank of gas to last me 60 miles. there are no leaks. Could it be because the carbs need to be adjusted or could there be a bigger problem. If it is carbs, could I have some directions on how to adjust them. Thanks guys!!
  • azman857
  • azman857's Avatar
Re: 1982 Kawasaki KZ 1100 A2
08 Sep 2021 19:35 - 09 Sep 2021 17:23
#855024
What do the sparkplugs look like?
Last edit: 09 Sep 2021 17:23 by azman857.
  • 750 R1
  • 750 R1's Avatar
08 Sep 2021 20:08
#855025
What do the spark plugs like?
Spark and fuel i'd imagine....
The following user(s) said Thank You: DOHC, SmithDubs
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
09 Sep 2021 08:17 - 09 Sep 2021 08:18
#855049
How does it run? That's a severe change in elevation so if it feels sluggish and the plugs are black I would check the jetting and compare it to stock. Plan on doing a complete teardown of the carbs (lot's of tutorials on this site) if you haven't already.
Oh, and let's see some pics!
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 09 Sep 2021 08:18 by ThatGPzGuy.
  • SmithDubs
09 Sep 2021 14:18
#855078
It runs pretty good - when I put the throttle down it lags for a second and finally goes. When I’m at a stop light I can smell light gas when Im at a stop light sometimes - Im at 60 miles now and it is below 1/4 of a tank. I know my father in law rebuilt the carbs and rejetted them - I’ll look at the spark plugs when I get home.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
09 Sep 2021 15:22 - 09 Sep 2021 15:23
#855081
How do you know where the fuel level/volume is???   Are you following a fuel gauge???
Last edit: 09 Sep 2021 15:23 by hugo.
  • SmithDubs
09 Sep 2021 16:03
#855084
I am - plus when
i shake the tank (bike) I can feel barely any fuel in the tank.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
09 Sep 2021 16:34 - 09 Sep 2021 16:35
#855085
..I could say run it until you need to switch to reserve, see how far you go.....but to play it safe;............ what if .....when you have 1/4 tank indicated, disconnect line from petcock to carbs (in ON position. am assuming is vacuum operated).   Connect a clear plastic tube from petcock to a 5 gallon container.    Set the petcock to prime, and let if flow until is completely empty and see how much gasoline you get on container.
........use a clean (or new) container.   You would return the gas to bike tank, so no one gets hurts, and you don't have anything to loose, other than a bit of work.
Last edit: 09 Sep 2021 16:35 by hugo.
  • SmithDubs
09 Sep 2021 17:03
#855087
I like that idea - I will let you know
