305 slide hole orientation
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
19 Aug 2021 13:35
#854071
 I noticed on JBM's page it says "slide holes on Honda CB 350 and 360 go on the intake side". With the stock diaphragms on my 305 there is only one way for the slides to go in so this is not addressed in the manual, but with the stock rubber gone now there are about numerous ways with these replacement JBMs because they aren't fixed in place. The rubbers can only go one way but the slide can go any way. I'm going to assume I should line up the holes on the bottom of the slide with the intake side as in the Hondas, unless I hear otherwise. jbmindustries.com/Keihin_diaphragm.html
81 KZ650 CSR
82 KZ305 CSR
  • TexasKZ
  • TexasKZ's Avatar
Re: 305 slide hole orientation
21 Aug 2021 12:12
#854151
