Gas tank cap
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
Gas tank cap
01 Aug 2021 21:17
#853017
Aloha guys. I hope I'm posting this on the right section.
For the life of me, I can't find my original gas cap. It should be somewhere as I don't think I'll throw away something I need down the line. Anyway, my question is just that. What do you guys use if you need a gas cap. Brand new Chinese copy or good used cap?
Found several on evilbay so getting one should be no problem. I'm just not sure about the quality of Chinese cap. If I decided to get the used one, I'll be sure to change the gasket, so don't worry about that.
Any thought or experience?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • hardrockminer
  • hardrockminer's Avatar
Re: Gas tank cap
02 Aug 2021 04:00
#853020
I would buy a used one if I needed one.  Reduce, Reuse, Recycle.
  • TexasKZ
  • TexasKZ's Avatar
Re: Gas tank cap
02 Aug 2021 05:02
#853023
I prefer gently used original or n.o.s.
  • martin_csr
  • martin_csr's Avatar
Re: Gas tank cap
02 Aug 2021 06:06 - 02 Aug 2021 07:43
#853027
I installed a repro fuel cap more than 5 years ago. high quality & works-fits fine.
Made in Taiwan & seems to be the same one sold at various places.*
Info on box: 20-0032 FUEL TANK CAP, #51048-1003 (Made in Taiwan).
note: the Kawasaki part number supersedes to 51048-1018 which is the part number for the stock fuel cap on my motorcycle.
PartsNmore Fuel Cap 20-0032: www.partsnmore.com/parts/kawasaki/kz650h/?q=20-0032
* ps: not to be confused w the cheap chinese knockoffs listed on EB.
Last edit: 02 Aug 2021 07:43 by martin_csr.
  • Ojisan rider
Re: Gas tank cap
03 Aug 2021 01:02
#853063
Thanks guys.
Yeah, I was bit worry about the Cheap Chinese cap, so good used one it is. So far, I haven't see any Taiwan made cap, but I'll try that as well.
  • martin_csr
Re: Gas tank cap
03 Aug 2021 05:49 - 03 Aug 2021 09:35
#853065
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe fuel caps at PartsNmore, Z1Parts.net & Johnny's Vintage Cycles are probably the same as the one I got.  I've only seen a few on EB made in Taiwan, but they usually cost more.   2FastMoto on EB has a couple, including an Emgo.
This one has the same keys as mine w the same logo, so probably the same.  2fastmoto item 202780280324 also has the same keys but the logo is hard to see. Alternatively, I wouldn't hesitate to get an emgo fuel cap. should be made in Taiwan.
EB. linked this one just to show the key logo. this seller's pricing is usually higher than others.
__________________________________________________________________________________________
Emgo 43-61014. Made in Taiwan.
Last edit: 03 Aug 2021 09:35 by martin_csr.
  • Ojisan rider
Re: Gas tank cap
03 Aug 2021 23:06
#853128
Oooooooooooooh, OK.
Yeah, I saw couple of those, including the 2FastMoto ones. Didn't realize that was Taiwan, but it did cost somewhere in the 20's. Found couple decent looking used cap as well, so not too sure which one I'll go with.
I'm kinda leaning towards the used Black cap I found......................
  • martin_csr
Re: Gas tank cap
04 Aug 2021 06:07 - 04 Aug 2021 06:21
#853131
If a black one is preferred, you could try painting a chrome one with Rustoleum bar-b-q grill paint.  I painted the manifold section of a nice muffler system w silver bbq paint & it has held up without peeling or anything.  I didn't sand or roughen the chrome, just cleaned it with a soft brass jewelers wire wheel to remove rust mostly from the welds.  Alternatively, engine paint may also work.  but I know the rustoleum bbq paint sticks to chrome.
Last edit: 04 Aug 2021 06:21 by martin_csr.
  • 750 R1
  • 750 R1's Avatar
Re: Gas tank cap
04 Aug 2021 15:09
#853162
No eBay APP ID and/or Cert ID defined in Kunena configurationNot cheap but...
