Kz550ltd carb woes
  • Kevin76
  • Kevin76's Avatar Topic Author
Kz550ltd carb woes
09 Jun 2021 10:54
#849892
Hi guys, I’ve been lurking in this forum for a while, recently bought my KZ550LTD which had been in storage for a vast number of years
anyway, a couple of months work got it back on the road but I do have a very slight issue.
my bike runs fine until the last 1/5 throttle, then it bogs down slightly
the plugs are showing a good burn.
one of the problems the bike had when I got it was a jammed ignition advance, which freed up quite easily…
but on investigation the main jets are 105’s instead of the 95’s I expected.
I wonder if the previous owner didn’t recognise the stuck advance and tried to compensate with a bigger main?
now…this is where it gets interesting.
The float bowl vent pipes are blocked off…and it runs beautifully like this.
if I unblock them it splutters a little and has no top end…
any advice?
  • hardrockminer
  • hardrockminer's Avatar
Re: Kz550ltd carb woes
09 Jun 2021 13:31
#849908
Are your floats set correctly?
The following user(s) said Thank You: Kevin76
  • loudhvx
  • loudhvx's Avatar
09 Jun 2021 16:05
#849920
Return things to stock per the manual and see what you got. It's possible the previous owner modified several things to compensate for perceived problems or misdiagnosed problems.
There is a link to Tk22 carb website in my signature. It has some hints not covered I the manual.
  • Kevin76
10 Jun 2021 04:54
#849943
Thanks for the advice guys,I changed the 105 jets for 95 and voila….normal service was resumed
simple case of over jetted
