Needle Jet remove
- Fox
Needle Jet remove
19 May 2021 11:42
Hello,
i'm a little bit lost.
I would like to remove the needle jet to chek is number.
Part N°26.
Do i have to do it from the top of carb ?
Best,
Fox
Part N°26.
Best,
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
Re: Needle Jet remove
19 May 2021 12:16
Once the needle jet tube ( AKA main jet holder or emulsion tube) is removed it taps out downwards in the direction of the float bowl from above though the slide bore.
19 May 2021 12:49
When pressing out the jet be sure that you don't press on the cup shaped edges or the edge may collapse.
- Saablord
22 May 2021 16:44
and use a soft punch. If your carbs are completely stripped, you can heat them up so the jets come out easier.
