VM24 viton tipped needle valves
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: VM24 viton tipped needle valves
06 May 2021 12:18
#848097
Just for your interrest. Found optimised Viton tipped needle valves kits for the VM carbs. Replace 16030-017, 16030-019, 16030-025, 16030-027 needles.
vergaser.saarbike.de/vergaser/et-oem-ver...r/kawasaki/index.php
vergaser.saarbike.de/vergaser/et-oem-ver...immernadelventil.php
The following user(s) said Thank You: 750 R1
  • 750 R1
  • 750 R1's Avatar Topic Author
06 May 2021 16:19
#848107
Thank's Scirocco,  Just making sure because i'm relying on a translation, they sell the needles separately, or is 16030-027, both needle and seat.... ?
I've also had trouble buying parts from Germany during the pandemic, I recently had to get a fuel cap sent to the UK to be onshipped to Australia because they wouldn't ship to Australia .
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 May 2021 03:54
#848135
The set comes with needle, seat and seal washer. If you need any help, i´m here...
  • 750 R1
07 May 2021 16:41
#848186
Thank you sir...!!
