1986 zx600a carb issue
  • brgtbird
  • brgtbird's Avatar Topic Author
24 Apr 2021 06:39 - 24 Apr 2021 06:40
#847354
1986 zx600a 22k miles
gifted to me from a military buddy
running pods with ths jetting it came with... looks like dynojet kit
carbs are clean, tank is clean, valves adjusted
starts easy on choke and runs great... issue i have is a wandering idle... carbs are synched.
another weird issue is when coming to a stop idle will drop then comes back.
float levels are dead nuts at 17mm. Is it running pods causing the idle issues?
Last edit: 24 Apr 2021 06:40 by brgtbird.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1986 zx600a carb issue
24 Apr 2021 07:32
#847360
If they are cheap filters, they may be blocking the air intake passages in the mouth of the carburetors, which will mess up the mixture. If they are from APE, K&N or Uni, they should be fine.
Wandering idle is usually a sign of a really lean mixture, caused by leaks around the carb holders or improper pilot mixture.
The idle drop when stopping is often a sign of a very rich mixture, or the idle speed is set much too low.
  • Nessism
  • Nessism's Avatar
24 Apr 2021 07:37
#847361
Are the carb boots original?  If so it's common for micro cracks to form which can lead to an erratic idle.  And spraying junk on them in search for air leaks doesn't always find them.
  • brgtbird
24 Apr 2021 09:38
#847364
Mew boots
carb synch is dead nuts
maybe I need to give mix screw half a turn out
  • brgtbird
24 Apr 2021 09:39
#847365
K&N filters
  • F64
  • F64's Avatar
  • 81-KZ440D2
24 Apr 2021 10:54
#847369
your float height is 17mm.
What is your fuel level coming in at?
81-KZ440-D2.
LIC, NY
