Sparkhole spitting fuel
  • MartyZ1000
  • MartyZ1000's Avatar Topic Author
17 Apr 2021 22:01
#846962
Welcome to Carb Twilight Zone, episode 845...
So I have fuel lock or near lock on cylinder #1 when bike´s been standing, KZ1000J3 with Mikuni BS34s,
the thread is helicoiled and not 100% so will have to redo that. But there is fuel visibly spitting out in between
plug and thread at the first starter turns, so regardless of thread there has to be fuel leaking in through inlet when bike stands still.
I´ve changed all the seat gaskets and needles in the floats, float levels look good
so my question is: is there anything else on the BS34 that could cause a leak when bike
is turned off?
  • rstnick
  • rstnick's Avatar
Re: Sparkhole spitting fuel
18 Apr 2021 06:02
#846967
On my kz650 and my ZRX I have installed manual petcocks/fuel valves.
This way everytime I park for hours, I turn the gas off.
No gas flows.
Neither sets of carbs on my bikes have overflow tubes.
This is why I use a manual petcock.
There must be an issue with carb #1 not closing off the fuel supply.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • Nessism
  • Nessism's Avatar
  • Away
18 Apr 2021 09:10 - 18 Apr 2021 09:12
#846984
The petcock should turn off fuel flow when the engine is off, just as long as the lever is set to either "ON" or "RES".  If gas is flowing with the engine off the petcock has failed.  Further, if fuel backflows down the vacuum line port to the carbs the petcock has failed as well.  The petcock "PRIME" feature allows fuel to flow at all times so make sure the lever is not set to that setting.  Prime is designed to fill the float bowls after a long time of inactivity.  Set to Prime, fill the float bowls, then switch lever back to ON/RES from thereafter.
Last edit: 18 Apr 2021 09:12 by Nessism.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
18 Apr 2021 11:39
#846991
Also note that if you have collected enough fuel to spray out of the plug threads, you have also probably collected a fair amount of fuel in your oil/sump.  Sounds like it's time to change your oil.
My zrx1100 carbs also do not have a drain tube, so when they overflow fuel pours into the engine.  Yes, this has happened to me.  I think I had about 2 gallons of fuel mixed in with the oil.
My dad's '74 Z1
'00 ZRX1100
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Apr 2021 14:33
#846995
Did you use oem float valves?
Aftermarket valves have issues with sealing.
81-KZ440-D2.
LIC, NY
  • MartyZ1000
19 Apr 2021 20:36
#847068
Thanks for all the feedback guys, I´m aware of how the petcock works, and I could use any carb´s vacuum port right?
had it hooked up to #2 at first but changed to #1 the last half year. Both Run and Res respond ok with vacuum turning
them on/off.
The carbs are in pretty good shape, I inspected the floats again yesterday (new needles and seats recently) and float
height looks good too. The floats themself are fine.
I emptied out the oil yesterday and it reeked of gas so will put some new oil in, put the carbs back on and give it another
try.
I also have pods on with bigger mains and run at three turns out on pilot now, but just ordered som new podfs
since the ones I´ve had on are old and done.
  • scubaanders
  • scubaanders's Avatar
19 Apr 2021 21:57
#847072
Check your PM Marty.
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • Kaylinator
  • Kaylinator's Avatar
21 Apr 2021 08:52
#847149
Suck on the vacuum line connected to your petcock. If you swallow fuel, the problem is your petcock.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Mikaw
  • Mikaw's Avatar
21 Apr 2021 11:52
#847165
Thanks for the laugh captain obvious
  • MartyZ1000
21 Apr 2021 13:41
#847170
Now I've both made and drunk some pretty lousy moonshine in my days but I'd never stoop that low. Not even for a petcock.
  • Kaylinator
21 Apr 2021 16:58
#847191
Haha. I mean, I suppose you could put a vacuum pump on it to check, but I guess the farmer in me just takes the easy route. A little fuel never killed anybody.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • MartyZ1000
21 Apr 2021 22:10
#847211
True! :)
And I did it just that way when I checked it a couple of months ago, the vacuum function seems good. Now I got a good phone
support crash course in swedish from Andlun who set me up for a more thorough check. First off to check that the tank is clean and
rust free, including an elaborate 4 step to do list if it´s not, how to really fix it. Then I´ll set the tank and carbs up to properly check
both fuel levels with the clear tube test  and that none of them are leaking.
