Gravity fed petcock overflow problem
  • UnseenKZ
  • UnseenKZ's Avatar Topic Author
09 Apr 2021 20:17
#846457
I built a chopper out of a 81 kz550 Ltd with tk22 carbs.
it has a narrowed sportster tank with a gravity fed petcock, and the carbs are constantly overflowing when the petcock is in the on position.
i don’t know if there is any way to remedy this, I’ve tried adjusting the floats, and made sure the float needles are functioning properly. And all attempts have been fruitless.
I did the same sort of setup on an 82 kz750 Ltd with CV carbs and the same thing is happening.
any advice is appreciated, thanks.
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Gravity fed petcock overflow problem
09 Apr 2021 21:12
#846458
Make sure your overflow pipes are not cracked.
81-KZ440-D2.
LIC, NY
  • hardrockminer
  • hardrockminer's Avatar
10 Apr 2021 05:06 - 10 Apr 2021 05:07
#846462
The clearance between the floats and the edge of the bowl is very tight.  It's easy to spread the floats out by accident while bending the tang.  You need to ensure the floats are not catching on the bowl.  I had that issue on my wife's 550.
A member has a website here with a lot of info on TK22 carbs.
gpzweb.s3-website-us-east-1.amazonaws.co...stmentsAndMaint.html
Last edit: 10 Apr 2021 05:07 by hardrockminer.
