BS34 - To needle swap, or not to needle swap
  • OkieZ1000
  • OkieZ1000's Avatar Topic Author
09 Mar 2021 09:30
#844612
82 LTD 1000 K2 - Purchased 100% stock but the exhaust was in bad shape. I replaced with a Delkevic 4-1. The carbs were setup by the PO with 127 mains and different needles with a more aggressive taper (pics below).
I'm working to complete the setup and match the carbs and in lieu of a bunch of swaps I was hoping someone has some experience with a similar setup as to what the bike would "like" the best.
I've read the factory setup was normally lean in the midrange, so I even though I have a stock set of needles, I'm curious if this set with a more aggressive taper might help alleviate the mid-lean condition or should I just set it all back to stock 122.5 mains and stock needles, or some other combination.
As always, input is appreciated.
Thanks
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: BS34 - To needle swap, or not to needle swap
09 Mar 2021 19:21
#844657
Dyno Jet.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
