Carb adjustment order
- KennyJ
27 Feb 2021 20:11
Just wondering the proper order when adjusting your carbs. I have a 1976 kz900 Z1 which I have just recently put back together and got running the other day. The first thing I checked was to make sure the engine was bang on for the timing which it was.the second thing I done was synchronize the carburetors using my Mercury carb sticks the last thing I am going to do is to adjust the four air screws on the carburetors. After the air screw adjustments are done and the idle is set to the proper rpm should I recheck the carburetor synchronization with the carb sticks or should I assume that all is good
- krazee1
Re: Carb adjustment order
28 Feb 2021 08:22
You did it in the correct order doing the synchronization first. Optimizing your idle mixture does not change the vacuum, or amount of air being pulled through the carbs.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
The following user(s) said Thank You: KennyJ
- kevski
28 Feb 2021 08:43 - 28 Feb 2021 08:44
Did you bench sync the slides before putting the carbs back on?
Last edit: 28 Feb 2021 08:44 by kevski.
- zed1015
28 Feb 2021 09:10
No harm re-checking the vac readings but as already mentioned, fine tuning the pilot mix won't change them.
