81 kz1000 csr float bowl question
  • sean1980
  • sean1980's Avatar Topic Author
19 Feb 2021 12:38
#843724
Im working on my 81 kz1000 csr and i pulled the carbs and while taking them apart i noticed the float bowl half covers a hole on the carb body..i included a pic...they are mikuni bs34s if im correct..the gasket doesnt seem right but when searching thats the only one i can find.
81 kz650 csr
81 kz1000 csr
09 kz versys 650
  • Nessism
  • Nessism's Avatar
Re: 81 kz1000 csr float bowl question
19 Feb 2021 16:22
#843739
I'm not familiar with every possible variant of those BS34's but typically that passage is blanked off. You might want to remove the float bowl and probe the passage to see where if anywhere it goes.
