Z250 ltd needle position
- spooky
17 Feb 2021 09:17
1980 Z250 (single) with standard Keihin pr26 carb, question is what position should the needle be in ? I think there are 5 positions to choose from...
Re: Z250 ltd needle position
17 Feb 2021 14:17 - 17 Feb 2021 14:18
Putting the clip in the middle (third slot) is a good starting point.
Upper slot = lowering the needle = leaning mixture,
Lowest slot = raise the needle = fat mixture.
Last edit: 17 Feb 2021 14:18 by Scirocco.
The following user(s) said Thank You: spooky
17 Feb 2021 17:59 - 17 Feb 2021 18:13
The factory service manual should have that information.
Last edit: 17 Feb 2021 18:13 by TexasKZ.
- spooky
19 Feb 2021 07:49TexasKZ wrote: The factory service manual should have that information.
should be but it`s not...
