Tiny little O-rings on mixture screws
- ckahleer
16 Feb 2021 19:18
I should of asked this question 10 years ago. Every time I pick up a fixer upper, I spend way too much time and frustration trying to get those little o-rings out of the carburetors.
Any tricks or tools I should be using?
What size are they? Where do I get a bunch of them?
Thanks
Thanks
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Re: Tiny little O-rings on mixture screws
16 Feb 2021 19:20
What year, bike, carbs, are we talking about here?
17 Feb 2021 06:10 - 17 Feb 2021 06:36
No eBay APP ID and/or Cert ID defined in Kunena configurationPartzilla has part numbers. Z1Enterprises.com has o-ring dimensions.
The EB o-rings below should fit my carburetor pilot adjusting screw orifices, since the dimensions match.
I didn't do an exhaustive search & viton might be preferable to nitrile. note: seller doesn't say how many o-rings are in a pack.
EB: Othmro Nitrile Rubber O-Rings 5.5mm OD 2.5mm ID 1.5mm Width, Metric Buna-N Pack
Last edit: 17 Feb 2021 06:36 by martin_csr.
