New Petcock
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: New Petcock
13 Feb 2021 16:55
#843447
No eBay APP ID and/or Cert ID defined in Kunena configurationThe one in your link has 46mm spacing between mounting bolts.
The 650's is 44mm.
I bought one of these manual petcocks for my '78 KZ650 C2.
Haven't installed it yet, will in the Spring when I fire her up again.
Not the best looking fuel valve, but works well as confirmed by another 650 rider.
It goes on reserve much earlier though I hear.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • martin_csr
  • martin_csr's Avatar
Re: New Petcock
14 Feb 2021 06:39 - 14 Feb 2021 06:42
#843458
Vacuum petcocks.
Z1Enterprises.com should have a Suzuki petcock that will work. assuming they still carry it.
For OEM a KZ1000P petcock should work. I'm pretty sure it's 44mm, but ask before buying.
82-2001 www.partzilla.com/product/kawasaki/51023...1d5e2841c7787bef24b#
2002-05 www.partzilla.com/product/kawasaki/51023...f6d6d107f30cbf4662c#
Last edit: 14 Feb 2021 06:42 by martin_csr.
  • ghostdive
  • ghostdive's Avatar
Re: New Petcock
14 Feb 2021 07:10 - 14 Feb 2021 07:11
#843460
I would go with the Tour Max petcock linked earlier, or something similar - I'm sure your mounting hole spacing is 44mm.
EDIT: I wouldn't go too cheap on this though. I've tried a couple $15 ebay taps and they may as well have been sieves.
2001 ZX-6R
Last edit: 14 Feb 2021 07:11 by ghostdive. Reason: Clarification.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: New Petcock
14 Feb 2021 07:54
#843462
I combined the two threads.
  • xstreamcanadian
  • xstreamcanadian's Avatar Topic Author
Re: New Petcock
14 Feb 2021 10:14
#843466
Yeah I was wondering about that. I bought the rebuild kit and its all new, so no reason it wont work. Found the port between the #1 and #2 carb meant for the line to the petcock, according to the internets. Im going to try it and see. I was also wondering can you just remove the diaphragm part and plug the input port? Probably. Either way, going stock, to see what happens. Also replaced my cam cover gasket yesterday, my shop is -4 Celsius right now so that sucked.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: New Petcock
19 May 2021 18:05
#848750
The 650's is 44mm.
EDIT: This petcock has failed on me.
At just under 500 KMs, when set to ON, it barley flows.
When set to OFF, it constantly drips.
The lever is getting hard to turn.
Ethanol in the gas may be a contributing factor.
Haven't taken apart the petcock yet.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
