Fuel "T" tube leaking
- Bluegoose
10 Feb 2021 18:03
Hi good friends
1981 LTD 750 H1
Just noticed a gas leak at the "T" fuel tube. It doesn't appear to be cracked but fuel is leaking at the area where the tube goes into carb #3. I see there are o rings available for it on partszilla so I plan to order a couple. Does this sound like the fix or is there something else I should be looking at? Also I'm wondering can I keep carb #4 and #3 connected when I take it apart or do they need to be taken apart separately (I've never taken them apart before). Thanks for any and all enlightenment you can provide.
1981 LTD 750 H1
1981 Kawasaki LTD 750
Re: Fuel "T" tube leaking
10 Feb 2021 18:48
You will have to take the carbs off the rack to remove the T.
The following user(s) said Thank You: Bluegoose
10 Feb 2021 18:54
O-ring sizes
Pilot Screw: 1.2 x 2.6
Pilot Plug: 1.5 x 2.8
Fuel Transfer Tubes: 2.0 x 5.5
Drain Screws: 1.4 x 4.0
Float Bowl: 2.0 x 67
- Warren3200gt
11 Feb 2021 04:44 - 11 Feb 2021 04:47
I think the fuel t and carb fuel couplings o ring size is 2 X 8 for mikuni VM carbs. Not sure what's on your bike?
Last edit: 11 Feb 2021 04:47 by Warren3200gt.
11 Feb 2021 04:53Warren3200gt wrote: I think the fuel t and carb fuel couplings o ring size is 2 X 8.
O-rings are sized by thickness and ID. 2.0 x 5.5 is the correct size. I buy O-rings in bulk because I restore a lot of carbs for people.
The O-rings on the Tee and fuel transfer tubes get exposed to the outside environment and are the first to get hard and brittle. They typically literally crack and crumble when removing them.
Unganging the carbs is a bit of a pain but necessary when rebuilding a set. The challenge with the CV34's is the choke system. You might want to take photos of the linkages and how that tiny spring fits in the system. I use red loctite on the butterfly screws when replacing them and I also upset the head just like the factory does. I made a small nub by grinding a piece of file, then that gets positioned in the backside of the screw and it gets pinched with high leverage pliers to flare out the end. I've got photos showing the process if anyone is interested.
The following user(s) said Thank You: Bluegoose, Rick H.
- katit
11 Feb 2021 08:31Interested!Nessism wrote: I've got photos showing the process if anyone is interested.
11 Feb 2021 12:58
First photo shows the nub made from a piece of file stuck to some channel lock type pliers using modeling clay.
Second photo shows screw being flared.
Third photo shows the nub stuck in the back side of the screw after flaring. A pair of needle nose pliers is used to reach inside the carb and remove the nub from the screw.
The following user(s) said Thank You: Bluegoose, calum
- calum
11 Feb 2021 13:04
Thanks Ed. Do you pre-drill the ends of the screws?
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- Bluegoose
11 Feb 2021 13:33Keihin CV34Warren3200gt wrote: I think the fuel t and carb fuel couplings o ring size is 2 X 8 for mikuni VM carbs. Not sure what's on your bike?
- Bluegoose
11 Feb 2021 14:15Nessism wrote: O-ring sizes
Thank you good sir. Question, where do you purchase 0-rings in quantity? I know partszilla has them but lordy their prices. I'd love to get a bunch of these sizes for a furture rebuild as I have a spare set of carbs sitting around that I'd like to rebuild to have as a ready spare. Thanks!
11 Feb 2021 15:27
11 Feb 2021 15:36cycleorings has kits for Suzuki GS type BS (CV) and VM carbs and most of the sizes will fit KZ version Mikuni's, but not all. It's a good starting place though.
I get O-rings from either McMaster Carr or The O-ring Store. Buna N O-rings are fine, if not preferred for carbs, although some people like Viton.
The following user(s) said Thank You: Bluegoose, Mikaw
