'77 - '80 KZ1000 Airbox silencer tubes
  • Kaylinator
  • Kaylinator's Avatar Topic Author
07 Feb 2021 14:23
#843135
The airbox silencer I have for my KZ is missing the tubes that run down into it. I'm quite happy to run without them, but just realized I can probably get some 3D printed locally if I have the correct measurements.
Is someone able to provide this information? Need total length of tube, width and thickness of flange, and interior tube measurement. Figure I can measure the hole on my silencer to get the measurement of the outside of the tube.
Thanks in advance,
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Mikaw
  • Mikaw's Avatar
Re: '77 - '80 KZ1000 Airbox silencer tubes
07 Feb 2021 14:39
#843138
Could you post parts numbers or item numbers on a parts fishe. I have a 79 air box, it’s not complete. Might just have whatcha need
The following user(s) said Thank You: Kaylinator
  • Mikaw
  • Mikaw's Avatar
07 Feb 2021 14:50
#843140
Made it easier.
  • Kaylinator
07 Feb 2021 15:11
#843142
See circled.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Mikaw
  • Mikaw's Avatar
07 Feb 2021 15:48
#843145
Send me your address thru PM. I’ll trust ya with this one to have some 3D printed
  • Kaylinator
07 Feb 2021 15:58
#843146
You, sir, are way too kind. PM sent.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
07 Feb 2021 15:58 - 07 Feb 2021 16:00
#843147
I have one of those too. Alternately, instead of mailing the actual tube, I could draw it up in CAD with onshape and share the model with you.
My dad's '74 Z1
'00 ZRX1100
Last edit: 07 Feb 2021 16:00 by DOHC.
  • Mikaw
  • Mikaw's Avatar
07 Feb 2021 16:06
#843149
DOHC wrote: I have one of those too. Alternately, instead of mailing the actual tube, I could draw it up in CAD with onshape and share the model with you.
Either. Kaylinator your call.
  • Mikaw
  • Mikaw's Avatar
07 Feb 2021 16:09
#843151
Got to thinking I had seen something really similar recently. Found what I was thinking of. It’s found inside the shock spring on my 1976 mullholland shocks. You could make it work.
  • Kaylinator
07 Feb 2021 16:17
#843152
That might be a better plan if you wouldn't mind. Avoids the risk of losing parts in the mail. My faith in mail systems has been shook lately.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Mikaw
  • Mikaw's Avatar
07 Feb 2021 16:19
#843153
Can the dimension (program) be posted somewhere on the forum for future use
  • Kaylinator
07 Feb 2021 16:19
#843154
Mikaw wrote: Got to thinking I had seen something really similar recently. Found what I was thinking of. It’s found inside the shock spring on my 1976 mullholland shocks. You could make it work.
My first thought a few months ago was a plastic drain tailpiece, but that didn't quite work. Can't remember why.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
